Post by midlifecrisisrd on Feb 17, 2021 11:25:35 GMT 1
New rad cover and the N model bottom covers Steve
Post by Gunny on Feb 17, 2021 12:53:22 GMT 1
that rad cover in the "leftovers" pile was it?
Post by midlifecrisisrd on Feb 17, 2021 13:31:23 GMT 1
that rad cover in the "leftovers" pile was it? Knew you'd be all over this 😆 Yeah, leftover at Norbo's 😂 I actually have the cover the corners came off but there is a mark on it and a bit of distortion on the top edge that would need heated and sorted but I'd deemed it not good enough. I'll keep this one for a possible survivor build as got a bodyset in original paint 🤔 Steve
Post by JonW on Feb 18, 2021 0:03:46 GMT 1
Steve Didnt the 84/4 bikes also have that same rad cover? Thats what Ive fitted to my LC2 build... hmm...
Post by midlifecrisisrd on Feb 18, 2021 9:50:50 GMT 1
Steve Didnt the 84/4 bikes also have that same rad cover? Thats what Ive fitted to my LC2 build... hmm... Same cover but the 83/4 doesn't have the corners (UK market anyway) On them the belly pan locates into the bottom of the rad cover and hides the bottom rad spigot and the mounting bolts The corner pieces tidy it up when no belly pan is fitted (they are 29l part numbers so most likely fitted to the Jap/Aus earlier naked bikes) Steve
Post by JonW on Feb 18, 2021 12:44:40 GMT 1
Steve Didnt the 84/4 bikes also have that same rad cover? Thats what Ive fitted to my LC2 build... hmm... Same cover but the 83/4 doesn't have the corners (UK market anyway) On them the belly pan locates into the bottom of the rad cover and hides the bottom rad spigot and the mounting bolts The corner pieces tidy it up when no belly pan is fitted (they are 29l part numbers so most likely fitted to the Jap/Aus earlier naked bikes) Steve Ahh cool, good to know. I may well have a set of spares when i fit the belly then. Schweet.
Post by midlifecrisisrd on Feb 18, 2021 20:57:27 GMT 1
Rad cover fitted now Also swapped the rear spindle to go in the other way round The head is shallow and there was more clearance between the swinger and the can on one side so inserted from other side with a washer under the head so clears better now Also swapped the double nut on the end to a high tensile nyloc Then fitted the 3d printed horn cover Steve
Post by arrdy350 on Feb 18, 2021 21:19:45 GMT 1
Looking good 👍 really liking the horn cover 😀
Post by midlifecrisisrd on Feb 28, 2021 15:32:25 GMT 1
Just a little bit of side panel adjustment needed Steve
Post by abar121 on Feb 28, 2021 16:27:54 GMT 1
Looking good!
Post by Mr Kipling on Feb 28, 2021 18:54:33 GMT 1
Just a little bit of side panel adjustment needed Steve Looking so sweet....
Post by mouse on Feb 28, 2021 19:16:04 GMT 1
Loving it Steve! Are you fitting a bellypan and fairing?
Mouse
Post by itsnick350 on Feb 28, 2021 19:42:43 GMT 1
I am still catching up on various threads(I joined in October 2020), have to say I wish I known about this forum before I bought my 31k, loving the look of this and clearly built my somebody who takes pride in what they are doing. Will it be up for sale?
Post by midlifecrisisrd on Feb 28, 2021 19:51:05 GMT 1
Loving it Steve! Are you fitting a bellypan and fairing? Mouse Cheers mate I had thought about it but I made the financial decision to keep it naked Between the bracket, panels, paint and kidney clocks it added over a grand to the build cost that I reckoned I'd struggle to get back as it's ultimately a seller Steve
Post by midlifecrisisrd on Feb 28, 2021 19:52:31 GMT 1
I am still catching up on various threads(I joined in October 2020), have to say I wish I known about this forum before I bought my 31k, loving the look of this and clearly built my somebody who takes pride in what they are doing. Will it be up for sale? Thank, one does one's best 😁 Yes it's for sale, got a couple of people showing an interest Steve
Post by stumpy on Mar 1, 2021 15:49:53 GMT 1
I am still catching up on various threads(I joined in October 2020), have to say I wish I known about this forum before I bought my 31k, loving the look of this and clearly built my somebody who takes pride in what they are doing. Will it be up for sale? Thank, one does one's best 😁 Yes it's for sale, got a couple of people showing an interest Steve Can you pm me a price please, trying to get back into another ypvs, thanks
Post by rsvr1000 on Mar 4, 2021 22:00:58 GMT 1
Just a little bit of side panel adjustment needed Steve Looks great Steve , did you have to leave off the centre stand for TSA pipes ?
Post by midlifecrisisrd on Mar 4, 2021 22:17:43 GMT 1
Just a little bit of side panel adjustment needed Steve Looks great Steve , did you have to leave off the centre stand for TSA pipes ? I never tried it with a stand as it had paddock stand bobbins Only the silencers are tsa, the chambers are Alonze/mutts Steve
Post by midlifecrisisrd on Mar 8, 2021 19:47:27 GMT 1
Watched it go in the back of kopite's van 😭
Post by Yogi on Mar 8, 2021 21:21:03 GMT 1
Watched it go in the back of kopite's van 😭 Steve Happy days hope you remembered to give Mike the paperwork 👍😂😂
Post by midlifecrisisrd on Mar 8, 2021 21:29:24 GMT 1
Watched it go in the back of kopite's van 😭 Steve Happy days hope you remembered to give Mike the paperwork 👍😂😂 Envelope stuffed down the front of the seat 😉 Steve
Post by Yogi on Mar 8, 2021 21:38:19 GMT 1
Happy days hope you remembered to give Mike the paperwork 👍😂😂 Envelope stuffed down the front of the seat 😉 Steve Might just put my Liberacy bling touches on it 🤣🤣🤣
Post by midlifecrisisrd on Mar 8, 2021 21:42:49 GMT 1
Envelope stuffed down the front of the seat 😉 Steve Might just put my Liberacy bling touches on it 🤣🤣🤣 I built it deliberately staying away from bling and using what I had but to be honest if it was blinged up it would be a stunner Just sort the side tail lining up first 🤣 Steve
Post by Yogi on Mar 8, 2021 21:48:01 GMT 1
Might just put my Liberacy bling touches on it 🤣🤣🤣 I built it deliberately staying away from bling and using what I had but to be honest if it was blinged up it would be a stunner Just sort the side tail lining up first 🤣 Steve The lump hammer is primed and ready to go 😱
Post by midlifecrisisrd on Mar 8, 2021 21:57:56 GMT 1
I built it deliberately staying away from bling and using what I had but to be honest if it was blinged up it would be a stunner Just sort the side tail lining up first 🤣 Steve The lump hammer is primed and ready to go 😱 Thought you were going to say you were going to cut the rear off the frame and fit a tan cafe racer seat 😁 It's like I can read your mind 😂 Steve
Post by Yogi on Mar 8, 2021 22:04:56 GMT 1
The lump hammer is primed and ready to go 😱 Thought you were going to say you were going to cut the rear off the frame and fit a tan cafe racer seat 😁 It's like I can read your mind 😂 Steve 😱 I’ve been rumbled 😂😂
avb
andys vapour blasting
Post by avb on Mar 8, 2021 22:17:03 GMT 1
ffs matt havent you got enough going on in the cave
Post by Yogi on Mar 8, 2021 22:20:31 GMT 1
ffs matt havent you got enough going on in the cave Lol, I need something to ride whilst I’m sending you the other parts for blasting 😂😂😂
Post by perazzi350 on Mar 8, 2021 22:24:58 GMT 1
Steve's last two builds now in Essex only 25 miles apart. might see Yogi out on the road sometime !!
Post by Yogi on Mar 8, 2021 22:26:10 GMT 1
Steve's last two builds now in Essex only 25 miles apart. might see Yogi out on the road sometime !! Look 👀 forward to it mate 👍😂
