Clutch
Apr 5, 2020 12:34:07 GMT 1
via mobile
Post by Dixie Dean on Apr 5, 2020 12:34:07 GMT 1
Hi guys on a 350 pv having probs with the clutch.it goes in gear but when you pull the clutch in nothing happens any ideas
Clutch
Apr 5, 2020 13:10:17 GMT 1
via mobile
Post by midlifecrisisrd on Apr 5, 2020 13:10:17 GMT 1
Has it been lying unused the plates can stick together
If it was previously ok do the following
Bump start it and change up to 3rd or 4th then keep rolling on and off the throttle. It will eventually free off
If you don't know the history/Just built it/bought as a non runner then pop the case off and have a look
Clutch
Apr 5, 2020 13:22:39 GMT 1
via mobile
Post by Dixie Dean on Apr 5, 2020 13:22:39 GMT 1
Hi Steve engine rebuilt about 3 years ago in a total bike rebuild fired up this morning,top of realease shaft will hardly move.
Clutch
Apr 5, 2020 13:58:37 GMT 1
via mobile
Post by midlifecrisisrd on Apr 5, 2020 13:58:37 GMT 1
It hasn't got an lc clutch case on has it
There is a nipple on the inside casting that hits the centre nut
Clutch
Apr 5, 2020 14:03:48 GMT 1
via mobile
Post by shaunthe2nd on Apr 5, 2020 14:03:48 GMT 1
I had similar and turned out to be the so called gen yam clutch cable but the inner was too long. Changed it and it was fine.
Clutch
Apr 5, 2020 14:04:54 GMT 1
via mobile
Post by Dixie Dean on Apr 5, 2020 14:04:54 GMT 1
I’ve not talken the clutch cover of but last time I did I think it had 4lo on it.
Clutch
Apr 5, 2020 14:07:26 GMT 1
via mobile
Post by Dixie Dean on Apr 5, 2020 14:07:26 GMT 1
Hi Shaun I don’t think it’s the cable as you can hardly move the arm on top of the casing.
Clutch
Apr 5, 2020 14:17:28 GMT 1
via mobile
Post by midlifecrisisrd on Apr 5, 2020 14:17:28 GMT 1
Does a ypvs oil pump cover fit on it
They don't fit an LC case
Clutch
Apr 5, 2020 14:36:22 GMT 1
via mobile
Post by Dixie Dean on Apr 5, 2020 14:36:22 GMT 1
Yes it does
Clutch
Apr 5, 2020 14:39:41 GMT 1
via mobile
Post by midlifecrisisrd on Apr 5, 2020 14:39:41 GMT 1
You have another problem then
Best drain the fluids and have a look
Clutch
Apr 5, 2020 14:41:36 GMT 1
via mobile
Post by Dixie Dean on Apr 5, 2020 14:41:36 GMT 1
Thanks
