jch
Post by jch on Apr 5, 2020 8:50:58 GMT 1
Hi guys
It’s been a while since I’ve been on here. My LC2 has sat for at least 5years after a full rebuild. Like most, I’ve got a bit more time at the moment so I started her up. 20 kicks later and away she goes, not bad!
Two things I’ve noticed are a whinning Rev counter and she smokes a lot. Is there anything that can be done about the noisy Rev counter and is anyone able to post a link to how to check/setup the oil pump please so I can double check this. I haven’t done this for a while and my Haynes is at my dads house.
Thanks James
Post by markhoopy on Apr 5, 2020 12:21:52 GMT 1
Has your oil pump been to Arrow? If not it might be worthwhile sending it to him to be checked and set up.
jch
Post by jch on Apr 5, 2020 13:58:00 GMT 1
No I don’t think it’s been anywhere. Can they be serviced/adjusted then?
Post by midlifecrisisrd on Apr 5, 2020 14:15:17 GMT 1
Best to get it cleaned out and new seals
The check valves get stuck with crud then the tank slowly syphons into the engine making it smokey
As for the tacho take the clocks apart and carefully oil the speedo head (the bit that spins off the cable)
If you keep using it you will shag it
Post by markhoopy on Apr 5, 2020 14:46:28 GMT 1
No I don’t think it’s been anywhere. Can they be serviced/adjusted then? If you send the pump to Gary he will strip, service and set it up for you - it will be better than a new one when you get it back Send him a message HERE
jch
Post by jch on Apr 5, 2020 16:33:21 GMT 1
Brilliant, thanks. I’ve just sent him a message
Is there anything else i should check RE the oil seeping down into the crank?
jch
Post by jch on Apr 7, 2020 20:22:09 GMT 1
Best to get it cleaned out and new seals The check valves get stuck with crud then the tank slowly syphons into the engine making it smokey As for the tacho take the clocks apart and carefully oil the speedo head (the bit that spins off the cable) If you keep using it you will shag it Steve Do I need to fully disassemble the Tac hi or do I just need to oil it at the back where the cable connects?
Post by midlifecrisisrd on Apr 7, 2020 20:24:08 GMT 1
You can try a squirt of oil up the drive and see
