Post by shergar on Apr 3, 2020 16:18:44 GMT 1
do i need the bike running to work my head / tail light on a lc2 ? cheers
Post by midlifecrisisrd on Apr 3, 2020 17:54:05 GMT 1
No
Works off the battery
Post by shergar on Apr 3, 2020 21:24:55 GMT 1
No Works off the battery Steve thanks steve . can you tell me , do the barrels need to be torqued down and if so how with the nuts where they are located ? do you know the torque on the head nuts of hand ? ta
Post by midlifecrisisrd on Apr 3, 2020 21:33:23 GMT 1
Can't remember the head, either 18 or 20, I'd have to check in the morning
Torque the head before the base nuts (Just have them finger tight)
There is a special tool to torque the base nuts. NK racing sell them
Back in the day I used to just use a ring spanner on them and tighten at diagnals
4 fingers straight out at 90 degrees to the spanner and tighten as much as you can with an open palm
Post by shergar on Apr 4, 2020 11:35:57 GMT 1
have just done the barrels as youv said steve if u get a chance to check on the head bolts please , paul
Post by muttsnuts on Apr 4, 2020 12:47:30 GMT 1
head torque is 18ftlbs, I do them to 20ftlbs, no issues with that, an 8mm bolt/stud will easily take 30ftlbs, noit that I am suggesting you tighten them to that as it will stretch them !
Post by midlifecrisisrd on Apr 4, 2020 13:57:57 GMT 1
So both my suggestions were right
Post by shergar on Apr 4, 2020 14:27:35 GMT 1
thanks for all the help men , p
