craigo
Post by craigo on Mar 28, 2020 22:36:30 GMT 1
Hi there . Il try to be brief. Just done engine rebuild . New crank , pistons , seals etc. New power valves and seals . Completely overhauled carbs and intake rubbers. New battery and plugs . It started 3rd kick and idles beautifully. As soon as I apply throttle it pulses or fires once a second no matter how much throttle it gets then will settle to a perfect idle again . Help very much appreciated!! 🙏🏻
Post by midlifecrisisrd on Mar 28, 2020 22:41:25 GMT 1
1st is it a 29k50 cdi
I had one that wouldn't rev or would have massive backfire
Also did you take the brass balls out the carbs and clean behind them as well as cleaning the emulsion tubes
craigo
Post by craigo on Mar 28, 2020 22:51:48 GMT 1
I didn’t take the brass balls out . How can this affect things ?
Post by midlifecrisisrd on Mar 28, 2020 23:16:21 GMT 1
It's the air correction circuit
If it's blocked it causes all sorts of running issues
craigo
Post by craigo on Mar 28, 2020 23:51:18 GMT 1
My balls coming out !! Thanks
Post by wallcraft on Mar 29, 2020 0:10:07 GMT 1
Slides in the wrong carbs? Swap them around and try👍
craigo
Post by craigo on Mar 29, 2020 17:03:04 GMT 1
My balls coming out !! Thanks Just took the balls out and they were completely blocked with soda granules after vapour honing . Amazing! Thanks again
craigo
Post by craigo on Mar 29, 2020 20:57:11 GMT 1
Ok . Stripped carbs back down and removed all the crud from behind the brass balls . Put the carbs back in . Starts with choke 1st kick and idles perfect. Carb slides are with cutaway facing backwards ( towards air cleaner ) . Both slides are synchronised. As mentioned before; New crank, pistons, all seals , spark plugs, new stator from electrex, new throttle cables , new inlet rubbers etc etc .... From a perfect idle, if you apply throttle , doesn’t matter how much , it just fires just under once a second then when throttle is closed it goes back to a perfect idle . Could it be electrical? ? Help my wife please as I’m unbearable to live with until I can find the fault 😩😩
Post by midlifecrisisrd on Mar 29, 2020 21:53:05 GMT 1
What did are you using?
craigo
Post by craigo on Mar 29, 2020 21:56:02 GMT 1
Hi Steve. Sorry what do you mean ?
Post by JonW on Mar 30, 2020 3:52:22 GMT 1
What did are you using? Steve CDI?
Post by midlifecrisisrd on Mar 30, 2020 8:09:25 GMT 1
What did are you using? Steve CDI? Yeah Feckin phones 🙄 Steve
Post by midlifecrisisrd on Mar 30, 2020 8:12:00 GMT 1
Hi Steve. Sorry what do you mean ? Auto correct Should have asked which cdi you are using Early lc2 ypvs cdi's marked 29k50 are well known for having problems Usually cutting out after a little while but I've had misfired, overheating etc before Steve
craigo
Post by craigo on Mar 30, 2020 9:25:45 GMT 1
Hi Steve. I’ll check . Thanks . I’m wondering if the new stator I’ve fitted has damaged the original CDI . Never had this problem before so it’s taken me by surprise! 👍
craigo
Post by craigo on Mar 30, 2020 10:07:22 GMT 1
It’s a 1UA -50 I’ve got a 1992 f2
Post by Yogi on Mar 30, 2020 10:13:01 GMT 1
It’s the right cdi for the bike
Silly question but you have got the small balance tube fitted between the carbs and the vacuum from the right hand carb connected to the petrol tap
Matt
Post by wangwang on Mar 30, 2020 10:28:18 GMT 1
Does sound electrical, maybe nothing to do with your bike, but years ago I had a short on the indicator relay that caused the same sort of problems you are getting.
craigo
Post by craigo on Mar 30, 2020 11:34:49 GMT 1
Thanks for your feedback to date . I’ve got the pipe fitted between the carbs but not the vacuum pipe as I’m fueling the bike from an auxiliary tank that yambits sell .
Post by oldbritguy on Mar 30, 2020 13:28:23 GMT 1
You will need to block off the vacuum pipe if you are using a remote fuel feed. If you don’t block it off you will be drawing in too much air which certainly won’t help things.
Post by Yogi on Mar 30, 2020 13:52:18 GMT 1
You will need to block off the vacuum pipe if you are using a remote fuel feed. If you don’t block it off you will be drawing in too much air which certainly won’t help things. As above make sure the pipes blocked off
craigo
Post by craigo on Mar 30, 2020 14:02:32 GMT 1
My 92 ypvs doesn’t have a vacuum circuit . There’s only one take off pipe on the petrol tap .
craigo
Post by craigo on Mar 30, 2020 14:04:33 GMT 1
My 92 ypvs doesn’t have a vacuum circuit . There’s only one take off pipe on the petrol tap . The right hand carb stub is blanked off .
craigo
Post by craigo on Mar 30, 2020 14:05:15 GMT 1
Somebody put me right if this is incorrect!!
Post by Yogi on Mar 30, 2020 14:11:25 GMT 1
If it’s got a different tap with no vac then yes it should be blanked off
craigo
Post by craigo on Mar 30, 2020 14:39:05 GMT 1
Could I send a video to some who are happy to view it so you can hear what’s going on . It’s quite odd and something I’ve not seen on all the bikes I’ve restored . Thanks
craigo
Post by craigo on Mar 30, 2020 14:41:31 GMT 1
I’m crap with tech . Can a video be uploaded here ?
Post by Deleted on Mar 30, 2020 14:44:36 GMT 1
Stupid question I know, what happens if you put the fuel tap onto Prime?
Does the engine cut out ie it has flooded or does it keep on idling, it should flood if the tap is plumbed correctly
Reason I ask is if the issue isn't electrical, then it could be fuel starvation and putting onto prime may assist your search
Also it's the correct CDI but is it the correct flywheel, and is your coil pickup working as it should?
HTH
Post by tipfinchy on Mar 30, 2020 14:45:18 GMT 1
i have done it on here via flickr (i am also crap with tech) mart
craigo
Post by craigo on Mar 30, 2020 15:00:32 GMT 1
i have done it on here via flickr (i am also crap with tech) mart I replaced the stator for a direct replacement from electrex world but used the original flywheel
Post by beardy on Mar 30, 2020 15:09:53 GMT 1
Try Tapatalk. Even I can use it.
