RZ250R
Apr 7, 2020 7:58:00 GMT 1
Post by JonW on Apr 7, 2020 7:58:00 GMT 1
Wow, those are the best powdercoating bungs I've ever seen !! Dusty I was just thinking the same thing!
Post by fozzie1954 on Apr 7, 2020 18:18:38 GMT 1
Never been complimented on my bungs before must not let it go to my headππ€
Post by fozzie1954 on Apr 18, 2020 9:15:27 GMT 1
Post by fozzie1954 on Apr 18, 2020 9:23:35 GMT 1
Post by fozzie1954 on Apr 18, 2020 9:39:37 GMT 1
RZ250R
Apr 18, 2020 9:50:58 GMT 1
zig likes this
Post by fozzie1954 on Apr 18, 2020 9:50:58 GMT 1
Rusty and SNAFU water pump Bearing. P V joint screws didnt want to exit. nad to drill some of the fixings out. I could send you all to sleep with a long list !
RZ250R
Apr 18, 2020 10:37:29 GMT 1
Post by fozzie1954 on Apr 18, 2020 10:37:29 GMT 1
Please have a look at my " help and advice question ". Thanks
RZ250R
Apr 18, 2020 10:55:41 GMT 1
Post by stusco on Apr 18, 2020 10:55:41 GMT 1
How can a plastic dipstick damage an aluminium coarse thread?
RZ250R
Apr 18, 2020 11:06:53 GMT 1
Post by zig on Apr 18, 2020 11:06:53 GMT 1
Rusty and SNAFU water pump Bearing. P V joint screws didnt want to exit. nad to drill some of the fixings out. I could send you all to sleep with a long list ! really good project there....nice when you get it done attention to detail is key in any build so go brand new if it's not worth re-furbing ZiG
RZ250R
Apr 18, 2020 12:21:29 GMT 1
Post by muttsnuts on Apr 18, 2020 12:21:29 GMT 1
lots to do, be aware that if you intend converting that to a 350 then you will need a different ignition set up, as the stator/flywheel and CDI don't work so well on the 350 setup as the timing etc is all wrong, or at least the 2 bikes I've had in that where 250's converted to 350's ran terrible until I swapped it all out
Post by fozzie1954 on Apr 19, 2020 8:48:56 GMT 1
Hi all
Yes lots to do .... the clutch cover - somebody had rammed the dipstick in and cross threaded it and I assume the clutch gear wore a semi-circle out of it ! the cr*p collected in the "un-used" thread and upon trying to clean it and using a new dipstick it felt "cheesy" and 'orrible. Use of the tap was free and you cant clean a thread any better by any other method .
Thanks for the head up ref flywheel and if I get this to run at all - it will be a victory.I am hoping to go th Zeeltronic rout ... but need to talk more about it.
Post by Yogi on Apr 19, 2020 9:02:53 GMT 1
I rebuilt this 250 a while back and it was as smooth and quiet as any Iβve heard Not noticeably any slower once riding,itβs 46 bhp as standard Forward a few years and Iβm turning it into an hybrid due to using a lot of the original body parts on other bikes A decent set of pipes might even unleash a few more horses
RZ250R
Apr 27, 2020 13:24:54 GMT 1
Post by jediwhite on Apr 27, 2020 13:24:54 GMT 1
Great colour scheme, is it painted or stickers??
RZ250R
Apr 28, 2020 6:58:51 GMT 1
Post by JonW on Apr 28, 2020 6:58:51 GMT 1
lots to do, be aware that if you intend converting that to a 350 then you will need a different ignition set up, as the stator/flywheel and CDI don't work so well on the 350 setup as the timing etc is all wrong, or at least the 2 bikes I've had in that where 250's converted to 350's ran terrible until I swapped it all out Dave, I reckon you had some kind of CDI issue as the stator is the same on many 250/350s, ie on the 85 F1 57V 350 it uses the 51L stator and flywheel, which is a 250 part. They do use different CDIs of course and thats where the timing will be different.
RZ250R
Apr 28, 2020 9:01:37 GMT 1
Post by shaunthe2nd on Apr 28, 2020 9:01:37 GMT 1
Nice thread, keep up the good work. it looked a dog at the beginning but looks fairly complete. I'm surprised that your powder coater doesn't bung up all the threads etc for you as part of the process, but at least you seem to have it covered. Good luck with it and keep the pics coming.
RZ250R
May 2, 2020 6:11:27 GMT 1
Post by fozzie1954 on May 2, 2020 6:11:27 GMT 1
Hi Shaun
Didn't ask the painter to do any of the " masking " as I've had other frames etc coated and on return, although the promise has been made of thorough bunging etc the threads and bearing surfaces have not been done ! Then lots of work to clean/tap as needed.
Also the comment was made " you've done lots of the work " and the cost was lower for the powder coat of frame and swinging arm .... not much over Β£100 !
Try for more Piccies tomoz . thanks for the encouragement.
Post by fozzie1954 on May 3, 2020 7:40:05 GMT 1
Post by fozzie1954 on May 3, 2020 7:45:43 GMT 1
Post by fozzie1954 on May 3, 2020 7:50:38 GMT 1
Post by fozzie1954 on May 3, 2020 7:53:56 GMT 1
Time for the piston extractor ... but no adaptor big enough .... so made two ( fronts and rears the ID of the piston are different )
Post by fozzie1954 on May 3, 2020 7:58:57 GMT 1
Post by fozzie1954 on May 3, 2020 8:15:40 GMT 1
Seen a post on here ... reference ordering from Norbo , yes is a bit of a " rig ma roll " to order, as I'm a dinosaur asked my lady to help and in double quick time she " clicked and pasted " straight from the site to a word doc and then same again to P/Pay note.
Now the point of the comment " THE SERVICE FROM NORBO WAS OUTSTANDING " ordered after mid day Friday and received in the post Saturday !
Initially using the Forum I tried to use Flikr for photos with no joy ... now use Tapatalk after sound advice ( thanks Guys ) . Have paid for the premium service and now everytime I try to "load" one than 1 photo the app crashes ! ARGH ! any comment /advice welcome.
RZ250R
May 3, 2020 15:54:30 GMT 1
via mobile
Post by midlifecrisisrd on May 3, 2020 15:54:30 GMT 1
My tapatalk played up for a day or two after upgrading
If it keeps playing contact them, they are very helpful
RZ250R
May 4, 2020 6:15:05 GMT 1
via mobile
Post by fozzie1954 on May 4, 2020 6:15:05 GMT 1
Please have a look at my request for help ref my mate's YR5 ..... hope it's in the right section... please advise ?
RZ250R
May 8, 2020 16:51:42 GMT 1
Post by fozzie1954 on May 8, 2020 16:51:42 GMT 1
A simple question and you may call me Homer after ! Fitting the air cleaner box - is all that holds it one 6 mm fixing and two rubber mountings ? The reason I'm asking is that on the frame, underneath and to the rear of the plastic molding there are two pierced holes - quite large in diameter ,the forward one a smaller size didn't know if this hole should have a "rubber rest" for the air box. I've fitted the one that was on the bike originally to the rear of the two but cant see what purpose it carries out . I'll change to the mobile and post a couple of piccies
RZ250R
May 8, 2020 16:57:07 GMT 1
via mobile
Post by midlifecrisisrd on May 8, 2020 16:57:07 GMT 1
Big rubber bung goes in one of those holes above the shock mount
Other than that yes just the one bolt
Post by fozzie1954 on May 8, 2020 17:05:37 GMT 1
What's it there for Steve ?
RZ250R
May 8, 2020 17:25:18 GMT 1
Post by Yogi on May 8, 2020 17:25:18 GMT 1
Two stroke tank sits on it
RZ250R
May 8, 2020 18:15:42 GMT 1
via mobile
Post by midlifecrisisrd on May 8, 2020 18:15:42 GMT 1
What Matt said π
Post by fozzie1954 on May 31, 2020 6:41:51 GMT 1
