Post by perazzi350 on Mar 26, 2020 15:07:17 GMT 1
Guys I need a close up photo of where the side panels meet the tank on an lc from side on, I need it for my new painter so the speed blocks line up from tank to side panel, he never done lc before so please if you could post one or WhatsApp to 07866446444 be much appreciated. Steve
Post by shaunthe2nd on Mar 26, 2020 15:55:26 GMT 1
Have you seen this link? www.bike-stickers.com/RDLC%20Tanks.htmIf you scroll down you will see a description of fitting the Speedblock decal to the tank. This is written by a very skillful fella who does it all the time for The Image Works, and he says its 11/10 for difficulty. He knows. My suggestion would be get your painter to paint the tank, and add a couple of layers of lacquer, then take the set to Image works and get them to supply and fit the decals, then your painter can give last coats of lacquer. if your painter has never done an LC before he is going to struggle. image Works normally fit for free if you buy the decals. No brainer!
Post by perazzi350 on Mar 26, 2020 16:40:31 GMT 1
Have you seen this link? www.bike-stickers.com/RDLC%20Tanks.htmIf you scroll down you will see a description of fitting the Speedblock decal to the tank. This is written by a very skillful fella who does it all the time for The Image Works, and he says its 11/10 for difficulty. He knows. My suggestion would be get your painter to paint the tank, and add a couple of layers of lacquer, then take the set to Image works and get them to supply and fit the decals, then your painter can give last coats of lacquer. if your painter has never done an LC before he is going to struggle. image Works normally fit for free if you buy the decals. No brainer! Hi, yes I’ve seen this before but I am having it all airbrushed so needed someone to send me a photo close up cheers
Post by alankelly on Mar 26, 2020 18:39:00 GMT 1
Post by perazzi350 on Mar 26, 2020 19:12:49 GMT 1
Post by alankelly on Mar 26, 2020 19:42:51 GMT 1
No problem
If you need any more just pm me
Best wishes Al
