Post by 500RG on May 31, 2020 12:15:57 GMT 1
RS500
May 31, 2020 13:18:59 GMT 1
500RG likes this
Post by panzermatt on May 31, 2020 13:18:59 GMT 1
split link on a bike that powerful? has to be a rivet link.
Post by 500RG on May 31, 2020 15:26:55 GMT 1
split link on a bike that powerful? has to be a rivet link. I keep it split link until the final build - nothing wrong with a split link as long as itโs fitted in the correct direction ๐
Post by 500RG on Jun 1, 2020 7:42:52 GMT 1
Post by 500RG on Jun 2, 2020 12:14:50 GMT 1
RS500
Jun 3, 2020 14:52:51 GMT 1
rd84 likes this
Post by 500RG on Jun 3, 2020 14:52:51 GMT 1
Post by 500RG on Jun 3, 2020 15:25:50 GMT 1
RS500
Jun 4, 2020 7:55:23 GMT 1
via mobile
500RG likes this
Post by oldbritguy on Jun 4, 2020 7:55:23 GMT 1
Big step getting the first fire up. Usually accompanied by a big grin ๐ Nice one. On the road soon ๐
Post by 500RG on Jun 4, 2020 8:38:00 GMT 1
Post by 500RG on Jun 5, 2020 11:05:57 GMT 1
Post by 500RG on Jun 6, 2020 11:48:27 GMT 1
Post by 500RG on Jun 7, 2020 9:48:39 GMT 1
Post by 500RG on Jun 8, 2020 8:16:25 GMT 1
Post by 500RG on Jun 10, 2020 9:07:34 GMT 1
RS500
Jun 11, 2020 7:37:10 GMT 1
rd84 likes this
Post by 500RG on Jun 11, 2020 7:37:10 GMT 1
RS500
Jun 14, 2020 9:08:20 GMT 1
Post by 500RG on Jun 14, 2020 9:08:20 GMT 1
RS500
Jun 15, 2020 8:31:02 GMT 1
rd84 likes this
Post by 500RG on Jun 15, 2020 8:31:02 GMT 1
RS500
Jun 15, 2020 21:25:51 GMT 1
500RG likes this
Post by fatfreddy on Jun 15, 2020 21:25:51 GMT 1
That is lovely!
RS500
Jun 16, 2020 7:55:17 GMT 1
rd84 likes this
Post by 500RG on Jun 16, 2020 7:55:17 GMT 1
Post by 500RG on Jun 17, 2020 6:52:30 GMT 1
Post by 500RG on Jun 24, 2020 7:42:42 GMT 1
One of the major issues with any RG500 hybrid build is always the carburettors / clearance / filters and cool air flow. Due to the carburettors being mounted on the sides of the engine it gives minimal fairing clearance and hence little room for filters. I have decided to try and manufacture my own air box - one each side using polypropylene. This has been ordered but obviously at the moment most plastics are in high demand, or the companies supplying it are flat out supplying material for, or manufacturing Covid screens. It will be a new skill to me and I have taken a punt and bought a plastic welder - heat gun. If these prove successful I can hopefully mould a carbon fibre set off the back of them (literally). Initially I took a punt on a set of ram air ducting from a Yamaha R6, feeding air via the nose cone down a tube either side of the fairing - unfortunately although it fitted fairly well I encountered a couple of issues, the tray in front of my head stock which holds all the electrics didn't allow enough space for the ram air to fit with the aperture in the nose cone, secondlyย ย the radiator expansion bottle also blocked the path for the right air tube. So time for a rethink, most other RG500 hybrid builds that do have air boxes seem to go for the slots in the leading edge of the fairing - either side of the forks. This seems my only other option (apart from air scoops in the fairing locally to the carburettors - feeding into an air box either side, so I will design a polypropylene back plate that will fit to the carburettor intakes and be mirrored on both bank of carburettors (to keep air box capacity the same). There will be a thin rectangular duct each side that connects to the air box and travels forward to the edge of the fairing either side of the forks, the first issue is the smallest standard radiator fans I could find during the build (Yamaha R6) protrude either side of the radiator - which block the route for the rectangular air ducts. After much viewing of the Bay of E I found some smallish fans - so I took a punt and bought 2, after much hacksawing and filing they just about fit and more importantly do not protrude either side of the radiator, so that is hopefully the first part sorted, I am still waiting for the polypropylene to be despatched (3 weeks now) - I have also purchased 4 bellmouths which Swarf of the PB massive is slightly modifying. To be continued...................................................................
RS500
Jun 24, 2020 14:00:13 GMT 1
via mobile
Post by flames on Jun 24, 2020 14:00:13 GMT 1
Seriously impressive.๐๐๐
