RD350N1
Jun 21, 2020 13:54:54 GMT 1
Post by ERic350 on Jun 21, 2020 13:54:54 GMT 1
OK. Now I understand why I did not notice. The nipple for the oil supply is absent on the right sice carb. Channel is open. Where could I find a replacement nipple? And how do you mount it? With Loctite? I didn't notice this post, you can use some brass tube 3mm outer diameter, I used it on a GT200 carb, I think its the same size as RD as both use Mukini carbs, I have plenty to send you enough to repair your carb, about 2 inches and you can cut off any extra, gently hacksawing, it should just tap in with the plastic end of a screwdriver, be gentle, I put some superglue on the outer and did this, it worked, it does not have the flair'd end, just straight tube, so you will need some stronger than standard clips to hold the oil feed pipe on, just measure the outer diameter of oil feed pipe once fitted to the new nipple and order some clips off ebay, if you PM me your address I will send you a little bit enough to do the job. Thanks for the tip. Just looked it up in the Netherlands. Few Euro's. Will order some. You having to sent it is more expensive than me ordering it localy. But still. Thanks for the offer !
RD350N1
Jun 21, 2020 14:49:41 GMT 1
Post by tony2stroke on Jun 21, 2020 14:49:41 GMT 1
Well done.
Post by ERic350 on Sept 2, 2020 19:46:55 GMT 1
Used the great summerly conditions to do a lot of sanding, spraying and decaling. Love the result so far. Maybe add bottom fairing but this needs some fiddling with a 350N1. Finalizing the technical things and have it formaly imported with licence plate will be winter activity.
RD350N1
Jan 16, 2021 20:01:59 GMT 1
Post by ERic350 on Jan 16, 2021 20:01:59 GMT 1
It's running and picking up nicely. Love the sound. Probably first time I hear a RD350LC from close by. And I love it ! No idea about the exact rpm as the rev counter wasn't working. Not sure about that. Last owner butchered some of the wires.
Post by ERic350 on Jun 6, 2021 15:05:58 GMT 1
Temp is up. Rattle can time for some experimenting. Audi Nardo Grey... No. Start over. Ral9016 white, Ral3020 red and some black rimstriping... Yes ! Like it. Yamaha old school.
Post by tipfinchy on Jun 6, 2021 15:28:03 GMT 1
lovely job that looks well , like the single seat unit you need the right bike to get away with Audi nardo grey mart
Post by abar121 on Jun 6, 2021 16:09:36 GMT 1
Lovely. Love the paint and that single seat unit.
Is it from Ricambiweiss?
Cheers.
RD350N1
Jun 6, 2021 16:38:36 GMT 1
via mobile
Post by midlifecrisisrd on Jun 6, 2021 16:38:36 GMT 1
Seat unit is awesome
Post by ERic350 on Jun 6, 2021 19:11:33 GMT 1
Lovely. Love the paint and that single seat unit. Is it from Ricambiweiss? Cheers. No, Quality Works Japan. Seen a picture. Took me a long time to find it. www.qualityworks.jp/
RD350N1
Feb 1, 2022 19:51:23 GMT 1
via mobile
Post by f**kwhit on Feb 1, 2022 19:51:23 GMT 1
Hi I recently bought a lc350 ypvs from Germany also with no side stand. I have bought the same bracket as you,but I don't know the location to wwld it on. Can you offer any help.
Thanks
Neil
Post by ERic350 on Feb 8, 2022 21:24:57 GMT 1
Hi I recently bought a lc350 ypvs from Germany also with no side stand. I have bought the same bracket as you,but I don't know the location to wwld it on. Can you offer any help. Thanks Neil Have a look at the picture. Side stand ends close to footrest. And do little check on angle ;-)
