colbox
Post by colbox on Mar 24, 2020 9:16:27 GMT 1
Noticed my speedo clock bulb has gone how easy is it to change cheers
Post by shaunthe2nd on Mar 24, 2020 9:35:49 GMT 1
Which bike?
If its a 250/350 4L1 or 4L0 you need to remove the speedo/tacho unit to be able to get to the rear. I've never done it whilst on the bike as reckon it will be very difficult.
So... -disconnect speedo and tacho cable from rear of clock housing (if not finger tight, try with pliers) -disconnect 3 plugs to clocks from inside the headlight shell (need to remove 2 screws on headlight shell at approx 4 and 8 o'clock position to remove the glass) -clocks are connected by 2 off bolts (need 10mm socket and spanner to remove) to headstock. Note the mounting bracket should be sat under the mount bosses on headstock -once removed you can open up the black cases via 4 dome nuts on underside. 8mm socket if I remeber correctly -this will allow you to get to the internal wiring and the various bulb holders -once replaced, fit in reverse as above. Remember to fix clock bracket under the bosses, not on top.
Post by JonW on Mar 24, 2020 12:45:23 GMT 1
Its a pain on all our bikes i reckon if the dash is on the bike, but it is possible. Ive done them on all models and its slow work.
Post by earthman on Mar 24, 2020 22:52:01 GMT 1
Best to replace them with LED's rather than bulbs if you can, brighter and lasts longer.
