Post by arrow on Sept 7, 2020 19:32:26 GMT 1
Looks great, well done.
Post by Tobyjugs on Sept 7, 2020 23:11:05 GMT 1
Yeah Rob you've done a fine job
Post by 4l04ever on Sept 7, 2020 23:15:12 GMT 1
Cheers for all you comments.
Just a couple of small jobs to do then running-in time.
The pipes to go on have been repaired and just being painted, so should be on for the weekend.
Got to change front master cylinder. Tried a 1/2" one as some people said they work well on 350, but too much travel at lever, so refurbing a 5/8" one to try.
Got to fit headlight and horns and that should be it!
Post by steve63 on Sept 15, 2020 19:39:43 GMT 1
Brilliant job there 👍 Lots of inspiration for my build.
Post by 4l04ever on Sept 15, 2020 19:54:49 GMT 1
Headlight in. Pipes are on. Changed master cylinder to 5/8" one, but also getting new build-a-line hoses as others had a slight kink and do not want hose to rub front mudguard. Once lines come in (hopefully Saturday), then bleed front brakes, and fit new horns and cover. That should be about it.
Post by flames on Sept 15, 2020 21:13:02 GMT 1
Finished at the weekend???
This thread started less than 6 months ago.....
That is incredible!!!
Post by 4l04ever on Sept 15, 2020 21:15:25 GMT 1
Wanted to get MOT done, but brake lines won't be at shop until Saturday afternoon, so cannot fit them until Monday. :-(
Should have taken a lot less time, but been working on my cars and other bikes too.
Post by 4l04ever on Sept 23, 2020 19:53:37 GMT 1
2taol
Post by 2taol on Sept 25, 2020 19:44:31 GMT 1
looking good !
cnkxu1
Member is Online
Post by cnkxu1 on Mar 18, 2021 11:54:25 GMT 1
The 250 left hand headlight bracket has a mount for the horn, but the 350 one does not. Glad I found this comment while searching. I was trying to work out what the extra bolt hole was on the left hand headlight mount on my 350. I could not match it to a part in the catalog. Looks like previous owner used a 250 mount probably after a repair.
Post by shaunthe2nd on Mar 18, 2021 12:38:32 GMT 1
How did the jb weld work out on the exhausts?
Post by 4l04ever on Mar 19, 2021 22:30:40 GMT 1
Seems to be okay so far. It improved the pitting in the downpipes. Could have got it better still with more time, but was after good used bike look, rather than brand new.
Post by 4l04ever on Mar 19, 2021 22:33:04 GMT 1
Will have to get finished pics put up when I get a minute...
Post by 4l04ever on Mar 21, 2021 11:11:16 GMT 1
Finished pics....forgot to post these...
Post by 4l04ever on Mar 21, 2021 11:11:36 GMT 1
Post by 4l04ever on Mar 21, 2021 11:12:38 GMT 1
It went off for MOT after these pics and had some new BT46 tyres fitted :-)
Post by arrow on Mar 21, 2021 11:13:23 GMT 1
Very nice, well done.
Post by 4l04ever on Mar 21, 2021 11:16:35 GMT 1
The bike is actually running in on premix. The clear oil lines are just to check how the oil pump is running. They just go back into the top of the oil tank for now. Once run in, will change lines and connect up to carbs :@)
Post by firmstools on Mar 22, 2021 10:47:07 GMT 1
Bodywork stickered up... I appreciate the parts are about to be lacquered but they look great with a satin finish! I may steal that look for my bike
