Post by flames on Jul 29, 2020 20:39:33 GMT 1
Fitted tie bars Do you just offer up the tie bars and tighten? I got some for mine , they are slotted where they mount on frame. Weren't sure if supposed to pull tight 1st or anything like?
Post by 4l04ever on Jul 29, 2020 22:29:25 GMT 1
Fitted tie bars Do you just offer up the tie bars and tighten? I got some for mine , they are slotted where they mount on frame. Weren't sure if supposed to pull tight 1st or anything like? Mine were a tight fit, so had to force them in! You usually just bolt up at the rear and tighten the front in the slot where it sits.
Post by 4l04ever on Jul 30, 2020 22:10:36 GMT 1
Bike fired up for first time today :-)
Got to sort out cooling system, and bleed oil pump, plus a few more bits.
Post by oldbritguy on Jul 30, 2020 22:22:49 GMT 1
Always a nice moment when you get the first fire up after a build. Usually accompanied with a big grin Happy days
Post by 4l04ever on Jul 31, 2020 11:58:18 GMT 1
Got a few snagging things to sort, such as left carb over flowing. Checked needle valve and seat looked okay with no debris and worked when blew through it, so thinking it could be a leaking float. Will try replacing float later today.
Post by 4l04ever on Jul 31, 2020 12:05:06 GMT 1
If the float is leaking, I will give it a Viking burial :-)
Post by 4l04ever on Jul 31, 2020 19:40:53 GMT 1
Fixed fuel leak from carb. :-) The list is getting shorter...
Post by flames on Jul 31, 2020 19:48:43 GMT 1
That motor is a thing of beauty. I need to build one for my mantle piece.
Post by veg on Aug 1, 2020 18:52:57 GMT 1
Robs another on here thatβll build a bloody good motor π. Looking good mate. Another returns to the road. I do wonder how many are now on the road including imports.
Post by 4l04ever on Aug 1, 2020 21:00:46 GMT 1
This one has been off the road since 1984. UK bike. Back on the road soon
Post by 4l04ever on Aug 7, 2020 9:02:21 GMT 1
Found a small water leak from head gasket on left side. Looks like slight difference in cylinder heights, so... Whipped off the top end and took to my local engineering man to skim them on my big jig plate. The plate is what I would class as substantial as it still stands up with two cylinders hanging off the side of it. The plate was clocked and then the cylinders are skimmed as a pair. Now perfect. The jig plate can be used for YPVS cylinders if flipped over Fitted with new head and base gaskets and no more leak
Post by 4l04ever on Aug 7, 2020 9:04:22 GMT 1
If anyone wants their cylinders skimmed as a pair, drop me a pm and can give you Stuart's contact details. He is based in Rugeley. Cost would be Β£30 plus post.
Stuart can also skim heads and do rebores if you supply pistons.
Post by flames on Aug 8, 2020 10:11:56 GMT 1
Have noticed my barrels look uneven. When I get round to stripping the motor will look into why this is the case and maybe contact you for them details. Fantastic idea with the big plate.πππ
Post by 4l04ever on Aug 8, 2020 10:45:37 GMT 1
The plate was surface ground on both sides and is within one thou across both faces, so good for a reference surface.
Post by veg on Aug 8, 2020 11:18:44 GMT 1
That is such a brilliant idea Rob, good thinking .
Post by 4l04ever on Aug 11, 2020 8:40:54 GMT 1
Fitted chain and started bleeding brakes... Soon be test ride time. Also trying some of the ultra high temp JB Weld on the pitted downpipes.
Post by 4l04ever on Aug 17, 2020 23:37:23 GMT 1
Post by oldbritguy on Aug 17, 2020 23:57:01 GMT 1
That looks good. Should be real nice once painted.
I have a small ding on one of my lc pipes just at the hanger. I might give this stuff a go.
Post by 4l04ever on Aug 18, 2020 10:05:19 GMT 1
Those pipes were quite badly pitted on the headers, so be interesting to see if this JB Weld holds up. Might be a good fix for a few people.
Post by oldbritguy on Aug 18, 2020 14:37:35 GMT 1
I looked at a video on YouTube using this stuff on exhaust repairs and it looked like you just fill dents and cracks straight from the tub No mixing adhesive and hardener. I thought it would have been an epoxy mix but it is heat cured ! Intrigued to see how this works out for you.
Post by 4l04ever on Aug 22, 2020 0:26:11 GMT 1
Post by flames on Aug 22, 2020 9:37:46 GMT 1
Looking great. Is that the bodywork from the start of the build?
Post by bezzer on Aug 22, 2020 10:52:10 GMT 1
Cracking build thread Rob, gives me fresh enthusiasm to get mine done ππ».
Post by st66 on Aug 22, 2020 15:07:35 GMT 1
I like this ππcracking job mate
Post by 4l04ever on Aug 22, 2020 16:15:52 GMT 1
Looking great. Is that the bodywork from the start of the build? Yes. They were painted ages ago. Only just got round to getting stickers done. Hopefully get finished in next few weeks.
Post by 4l04ever on Aug 29, 2020 8:41:16 GMT 1
Post by yamark on Aug 29, 2020 15:48:34 GMT 1
Looking really good Rob, enjoying this build. Nice work on the skimming of the heads as well mate
Post by 4l04ever on Sept 6, 2020 19:34:45 GMT 1
Post by flames on Sept 6, 2020 19:41:42 GMT 1
Brilliant. Looks fantastic
Gord
Post by Gord on Sept 7, 2020 13:33:37 GMT 1
Incredible work on this build. Itβs given me lots of great ideas for mine. Thank you for such a great thread. ππ
