Post by 4l04ever on Mar 21, 2020 23:01:38 GMT 1
My mate Paul, who we built a 4L1 250 for, got asked by his mate if we could sort him a nice 4L0, so luckily I had a UK Matching numbers 4L0 project in bits, so started building it...
Post by 4l04ever on Mar 21, 2020 23:04:12 GMT 1
Post by 4l04ever on Mar 21, 2020 23:05:15 GMT 1
Post by badger1 on Mar 21, 2020 23:45:03 GMT 1
Paint looks so much better than powder coating.
Post by perazzi350 on Mar 22, 2020 15:21:58 GMT 1
Post by 4l04ever on Apr 11, 2020 14:03:08 GMT 1
Post by 4l04ever on Apr 11, 2020 14:07:16 GMT 1
Post by donkeychomp on Apr 11, 2020 21:50:01 GMT 1
Looks really good. How much space do you actually have! Oh, a letter J has fallen off that (ahem) Smart car... Alex
Post by 4l04ever on Apr 12, 2020 16:47:57 GMT 1
Found a good clutch basket and matched up a primary gear.
Post by 4l04ever on Apr 13, 2020 22:40:05 GMT 1
Post by 4l04ever on Apr 14, 2020 22:21:23 GMT 1
Post by stusco on Apr 14, 2020 22:25:43 GMT 1
Will those springs not make it a bit rough on the left hand
Post by 4l04ever on Apr 14, 2020 22:30:30 GMT 1
No, they are only 15% uprated. I also extend the clutch actuator arm by 10mm which makes the lever easier to pull. :-)
Post by JonW on Apr 15, 2020 3:45:11 GMT 1
No, they are only 15% uprated. I also extend the clutch actuator arm by 10mm which makes the lever easier to pull. :-) With a replacement or cut-n-shut? Interested to see this mod
Post by 4l04ever on Apr 15, 2020 16:09:18 GMT 1
Cut and shut plus some welding... Will post pics once this one is done. Makes the lever pull nice and easy. Just make sure you use an original Yamaha clutch cable.
Post by JonW on Apr 17, 2020 14:45:37 GMT 1
Cut and shut plus some welding... Will post pics once this one is done. Makes the lever pull nice and easy. Just make sure you use an original Yamaha clutch cable. Cool defo keen to see what you do here Rob. Sounds a good mod.
Post by martin2016 on Apr 17, 2020 17:35:06 GMT 1
great pictures and build
Post by 4l04ever on Apr 29, 2020 10:21:44 GMT 1
pic
Post by 4l04ever on Apr 29, 2020 10:47:04 GMT 1
pic
Post by 4l04ever on May 1, 2020 20:21:13 GMT 1
Post by 4l04ever on May 1, 2020 20:22:57 GMT 1
Post by 4l04ever on May 6, 2020 2:24:53 GMT 1
Clocks built up. All original casings and clock faces
Post by Tobyjugs on May 6, 2020 11:49:04 GMT 1
No, they are only 15% uprated. I also extend the clutch actuator arm by 10mm which makes the lever easier to pull. :-) Hi Rob extending the actuator arm will give you less movement by the clutch plates for the same amount of travel on the clutch lever. How does this feel in reality? Do you feel any clutch drag as in a bit more clunky or difficult to select neutral?
Post by 4l04ever on May 6, 2020 13:50:14 GMT 1
No, they are only 15% uprated. I also extend the clutch actuator arm by 10mm which makes the lever easier to pull. :-) Hi Rob extending the actuator arm will give you less movement by the clutch plates for the same amount of travel on the clutch lever. How does this feel in reality? Do you feel any clutch drag as in a bit more clunky or difficult to select neutral? Difference in movement at plates went down from about 1.5mm to 1.2mm, but feel was a lot easier and smooth. My mates 250 has this mod done and he can get neutral fine. It looks like warped plates are the most likely cause of neutral issues, including the fibre plates, which I had never checked before.
Post by 4l04ever on May 7, 2020 20:16:11 GMT 1
Post by oldbritguy on May 7, 2020 20:55:34 GMT 1
Looking really good Rob. This is going to turn out really nice. Do you use a smear of sealant on your gaskets or do you fit them as is? My cylinders are still at PJME so got a bit of time before I need to use my new gaskets😉 John
Post by 4l04ever on May 7, 2020 21:55:01 GMT 1
I put nothing on head gasket, Yamabond on the reed block gaskets and reed blocks, and a smear of grease on the other gaskets.
Post by peter007 on May 8, 2020 5:13:10 GMT 1
No, they are only 15% uprated. I also extend the clutch actuator arm by 10mm which makes the lever easier to pull. :-) How did you extend the clutch actuator arm mate would be good to get a description and some piccies 👍
Post by 4l04ever on May 8, 2020 13:05:00 GMT 1
No, they are only 15% uprated. I also extend the clutch actuator arm by 10mm which makes the lever easier to pull. :-) How did you extend the clutch actuator arm mate would be good to get a description and some piccies 👍 This one has not been done yet, but will be done soon. Will post up pics when done.
Post by 4l04ever on May 14, 2020 11:00:36 GMT 1
