Post by shergar on Mar 19, 2020 21:56:26 GMT 1
would anyone have a picture of the position of the W clip on the back of the 31k headlamp please ?
Post by JonW on Mar 20, 2020 2:40:43 GMT 1
Have a search as Im sure this has been asked a few times before
Post by Shytalk on Mar 20, 2020 15:12:50 GMT 1
Post by midlifecrisisrd on Mar 20, 2020 16:51:20 GMT 1
31k is similar to that LC pic but it goes where the tab joins the inner and outer rim together
Post by shergar on Mar 20, 2020 20:51:57 GMT 1
the head lamp on mine has a receiver on the lamp and one on the rim one sits into the other and then the W clip sits on top of the lamp receiver i think as thats the way it was when i took it apart but i have a feeling thats wrong cause it pushes the lamp out past the rim to far and even adjusting the spring screws will not bring it back in to level the lamp all round , how many W clips should there be on the back ? any advice ? ta
Post by midlifecrisisrd on Mar 20, 2020 21:11:40 GMT 1
There should only be 1 clip
I've had ones that the small locating brackets are bent making the rim stick too far out
Unfortunately I don't have an assembled one to hand
Post by shergar on Mar 20, 2020 21:22:41 GMT 1
i just found the same issue on another tread ( 31k 1983 ) page 4 , but i dont see a result anywhere .
Post by jon on Mar 22, 2020 10:56:14 GMT 1
There should only be 1 clip I've had ones that the small locating brackets are bent making the rim stick too far out Unfortunately I don't have an assembled one to hand Steve Within topic I think, but does an LC have 3 of these? Jon
Post by midlifecrisisrd on Mar 22, 2020 11:08:55 GMT 1
There should only be 1 clip I've had ones that the small locating brackets are bent making the rim stick too far out Unfortunately I don't have an assembled one to hand Steve Within topic I think, but does an LC have 3 of these? Jon Yes Steve
Post by Shytalk on Mar 22, 2020 18:24:51 GMT 1
i just found the same issue on another tread ( 31k 1983 ) page 4 , but i dont see a result anywhere . It’s not difficult to find a picture using the search...............
Post by shergar on Mar 22, 2020 20:16:21 GMT 1
sorry i ment to post that i found the pic but i still dont think its correct when fitted as theres no way there supposed to kick out as per ( 31k 1983 ) tread and the reply under ( Thats for the adjustment not to blind people. ) same as mine .
Post by midlifecrisisrd on Mar 30, 2020 19:09:29 GMT 1
In case anyone else has this prob here's some pics I just took while building one up Steve
