Post by headcoats on Mar 17, 2020 8:24:12 GMT 1
Having a mare trying to bleed the brakes on the build
Never used a radial master cylinder before and I know it has a bleed nipple on top to get the last bit of air out the chamber No more air bubbles are coming out of any bleed nipples but still haven't any pressure
Pistons have pumped out , had calipers off forks at all angles , tied the lever back overnight but this morning exactly the same
It was a brand new master cylinder (Nissin) (3/4) new brake lines and new stainless pistons and seals I had from Nick Chambers ages ago
Usually have a bit of a fight but this is refusing big time !
Post by ianboom on Mar 17, 2020 8:29:48 GMT 1
I used a syringe with rubber pipe on it and sucked the air out from all nipples!
Post by headcoats on Mar 17, 2020 8:53:19 GMT 1
It's a 3/4 (19mm) master cylinder , does this sound correct
These parts have been left unused for several years but the rear brakes bled up without too much protest
Post by rigga on Mar 17, 2020 20:54:43 GMT 1
Reverse bleeding, clamping the lever to the bar overnight, removing the complete system, and angling the calipers so the bleed nipple is the right position to get all the air out ....... can be buggers sometimes to get all the air out.
Post by chrisg on Mar 17, 2020 20:59:49 GMT 1
Can you force fluid in, using a syringe, through the calliper bleed nipple (whilst open). Always works for me on conventional systems.
Post by headcoats on Mar 17, 2020 21:01:12 GMT 1
I managed to do it this morning
I carried on just doing the lever in , crack the nipple open etc and although I didn't see any bubbles coming out. it did finally firm up !
Post by rigga on Mar 18, 2020 6:14:43 GMT 1
Now clamp the lever to the bar overnight, and maybe that will force any remaining air up into the master cylinder Res.
Post by headcoats on Mar 20, 2020 18:40:08 GMT 1
Does anyone have the correct dimensions for the RGV caliper pistons please
Post by perazzi350 on Mar 22, 2020 11:52:09 GMT 1
Does anyone have the correct dimensions for the RGV caliper pistons please Hi just measured some I took off my bike they measure 33.94 and 30.18
Post by headcoats on Mar 22, 2020 12:05:51 GMT 1
Thanks , my pistons are out of spec
I will add them to my expensive paperweight collection !
Post by LC_BOTT on Mar 22, 2020 13:51:58 GMT 1
Does anyone have the correct dimensions for the RGV caliper pistons please Hi just measured some I took off my bike they measure 33.94 and 30.18 thats good, same as I measured seems a bit strange that ones oversized and one undersized for the stated dimensions??
Post by headcoats on Mar 22, 2020 18:18:33 GMT 1
Got the factory specs (?)
33.84mm 33.934mm 22.6mm
30.150mm 30.200mm 22.6mm
Factory tolerance minimum/maximum and piston height
