Post by stevietee350 on Mar 16, 2020 16:44:40 GMT 1
Any tips on removing these Allen bolts ,I removed 2 bug the rest are solid ,If I grind off the head is the bolt seized into the alloy carrier ,would heating help?
Post by LC_BOTT on Mar 16, 2020 17:02:08 GMT 1
Yes heat gun on the wheel, and maybe a whack with a mallet, sounds like they have loctite on, and this needs melting/softening.
Post by stevietee350 on Mar 16, 2020 19:13:28 GMT 1
Thanks ,away dig out blowtorch now.Steve
Post by jon on Mar 16, 2020 23:04:23 GMT 1
Which model bike are you referring to?
Post by JonW on Mar 16, 2020 23:08:12 GMT 1
rattle gun with socket and hex key on the front. The only way to do it without killing them really.
Post by jon on Mar 16, 2020 23:42:36 GMT 1
Which model bike are you referring to? Jon The reason I ask is that an LC doesn’t have Allen bolts, but a YPVS does. A YPVS needs the carrier removing as it has nuts on the back of the bolts. Jon
Post by dusty350 on Mar 17, 2020 8:10:19 GMT 1
Good point Jon. Looking at his previous posts, looks like Stevie has a Pv.
Dusty
Post by midlifecrisisrd on Mar 17, 2020 9:07:55 GMT 1
I didn't answer as I thought it couldn't be ypvs as you would simply use a socket and wrench on the rear and only need the slightest grip on the Allen head to stop it turning
Post by stevietee350 on Mar 17, 2020 15:28:27 GMT 1
Thanks for help lads, sorry yes it's a 31k ,the nuts on back of carrier came off easily but the Allen bolts were bending my good allen socket ,but a bit heat on casting freed them off then I punched them out, refitted with coppaslip job done ,great.
Post by oldbritguy on Mar 17, 2020 16:43:55 GMT 1
Good news Stevie. Made the same mistake with my own 31k and butchered 3 of the bolts trying to get them out. Copper grease on reassembly will help the next sprocket change.
