Post by ziggy999 on Mar 15, 2020 17:45:36 GMT 1
Hi folks not been on here for a while. My F1 rebuild stalled for a while but back on it now with only some minor fettling to do. One thing that I can't seem to figure out though is the clutch. My clutch is really heavy. I have replaced the cable and checked the routing of the cable and the mark on the casing lines up with the lever on the engine. The clutch cable also seems too long as it is adjusted right out at the handlebars and is only just biting...any suggestions welcome.
Post by midlifecrisisrd on Mar 15, 2020 18:03:44 GMT 1
Is it a genuine f1 57v cable
The non genuine ones can be the wrong length and don't have Teflon liners so are heavy
Also may have non standard clutch springs in it which are too heavy
Post by Yogi on Mar 15, 2020 19:18:58 GMT 1
Also the F1 has a different clutch perch to other ypvs so if youโre using an lc2 perch the cable will have more slack,just a thought ๐ค
Post by ziggy999 on Mar 17, 2020 14:59:42 GMT 1
Clutch perch? Not sure what that is.
Post by ziggy999 on Mar 17, 2020 15:07:59 GMT 1
Is it a genuine f1 57v cable The non genuine ones can be the wrong length and don't have Teflon liners so are heavy Also may have non standard clutch springs in it which are too heavy Steve The clutch cable that's fitted has 51L-00 4j09 marked on it...should this be 57v?
Post by midlifecrisisrd on Mar 17, 2020 15:12:23 GMT 1
Is it a genuine f1 57v cable The non genuine ones can be the wrong length and don't have Teflon liners so are heavy Also may have non standard clutch springs in it which are too heavy Steve The clutch cable that's fitted has 51L-00 4j09 marked on it...should this be 57v? Sorry, think 51L is the right one Think throttle cable is 57v Steve
Post by Yogi on Mar 17, 2020 15:45:35 GMT 1
Clutch perch? Not sure what that is. The perch is what the clutch lever bolts onto Iโll get a pic of mine ๐
Post by ziggy999 on Mar 26, 2020 17:46:58 GMT 1
Clutch perch? Not sure what that is. The perch is what the clutch lever bolts onto Iโll get a pic of mine ๐ Does an F1 clutch cable have a metal 45 degree bend at the lever?
Post by davecroucher57v on Mar 26, 2020 18:02:27 GMT 1
The perch is what the clutch lever bolts onto Iโll get a pic of mine ๐ Does an F1 clutch cable have a metal 45 degree bend at the lever? yes.
Post by ziggy999 on Mar 26, 2020 20:37:22 GMT 1
Does an F1 clutch cable have a metal 45 degree bend at the lever? yes. I think that is the problem...my cable doesn't have 90 degree bend.
Post by midlifecrisisrd on Mar 27, 2020 13:32:13 GMT 1
Post by ziggy999 on Mar 27, 2020 18:10:56 GMT 1
Ah, thanks Steve...back to the drawing board then
Post by davecroucher57v on Apr 9, 2020 17:07:27 GMT 1
my fault,i replaced mine in 87. sorry.
