Post by lambert on Mar 12, 2020 8:06:17 GMT 1
Hi Guys, I’m after some advice from you Guru’s regarding my carb set up on F1 31k My left hand pipe produces quite a bit more smoke then the right hand side especially at start up. I’ve recently had her on the Dyno with good results, the guy seemed to think left side was okay and has tried to bring the right hand side up on pilot and needle to match. I run stock non PJ VM26 Mikuni’s. Left side currently 27.5 pilot, needle clip at No2 position, air screw 1.3/4 turns out. Right side currently 3.0 pilot, needle No3 clip position, air screw 1.5. So my queries are - is it okay having staggered jetting and to what degree? Why does Left hand side smoke more than right hand side? The engine is fully rebuilt with approximately 1,500 miles on her, runs and sounds sweet. By the way I have mildly tuned barrels or so I’m told and run 430 mains, foam pod filters and new bespoke pipes.
Post by stusco on Mar 12, 2020 8:18:30 GMT 1
I think they all smoke more on the left it’s something to do with it sitting on the side stand (I think) my RG does it as well im sure someone well tell me I’m talking shite though🤣
Post by lambert on Mar 12, 2020 8:24:07 GMT 1
Ha ha 😂 I’ve only got centre stand so can rule that out....
Post by midlifecrisisrd on Mar 12, 2020 9:39:03 GMT 1
If you are running the oil pump it is common for one of the check valves to pass due to crud stuck in them
As the oil tank is higher it Syphon through and dump oil into the crankcase which causes one side to smoke more
Post by muttsnuts on Mar 12, 2020 10:11:32 GMT 1
quite normal to run different jetting on each pot, far more commn that you think
Post by earthman on Mar 12, 2020 12:17:46 GMT 1
quite normal to run different jetting on each pot, far more commn that you think What would be the reason(s) for that then? Was it the same back in the day when these bikes weren't so old? Surely if the carbs etc were like brand new/well matched, shouldn't they have the same jets??
Post by beardy on Mar 12, 2020 13:52:37 GMT 1
quite normal to run different jetting on each pot, far more commn that you think Oh no. My ocd wouldn’t be happy with that setup.
Post by chrisg on Mar 12, 2020 17:11:15 GMT 1
If you are running the oil pump it is common for one of the check valves to pass due to crud stuck in them As the oil tank is higher it Syphon through and dump oil into the crankcase which causes one side to smoke more Steve My first thought.
Post by chrisg on Mar 12, 2020 21:17:59 GMT 1
If it was the RH side, it could also be the crank seal,I had this with a brand new seal,not Yamaha - buy cheap, buy twice but LH more than likely as above.
Post by mak595 on Mar 15, 2020 17:28:51 GMT 1
If you are running the oil pump it is common for one of the check valves to pass due to crud stuck in them As the oil tank is higher it Syphon through and dump oil into the crankcase which causes one side to smoke more Steve Steve, Out of curiosity, where are the check valves, in the oil pump or carbs?
Post by midlifecrisisrd on Mar 15, 2020 18:00:28 GMT 1
If you are running the oil pump it is common for one of the check valves to pass due to crud stuck in them As the oil tank is higher it Syphon through and dump oil into the crankcase which causes one side to smoke more Steve Steve, Out of curiosity, where are the check valves, in the oil pump or carbs? In the pump If you grip the round section the barbs go into and twist them the outlets come out The is a spring and a ball bearing that are pushed onto the valve seat Steve
Post by mak595 on Mar 15, 2020 18:03:19 GMT 1
Steve, Out of curiosity, where are the check valves, in the oil pump or carbs? In the pump If you grip the round section the barbs go into and twist them the outlets come out The is a spring and a ball bearing that are pushed onto the valve seat Steve Cheers Steve
Post by 4l04ever on Mar 15, 2020 20:06:48 GMT 1
Could also be dirt behind one ball and not the other...
Post by chrisg on Mar 15, 2020 21:37:33 GMT 1
Post by lambert on Mar 18, 2020 16:26:34 GMT 1
No oil pump I’m running premix... back to Muttsnuts appraisal with staggered jetting, could the difference be a couple of Increments higher or lower depending?
