Post by parrott500 on Feb 5, 2020 11:35:24 GMT 1
Why are there 2 types of main calipers shims, as i can`t properly assemble the right caliper as the shim is to thick. I have attached pictures the left is thinner approx .60 mm the right is thicker approx .80mm obvious difference the left has a hole punched into it. Any ideas. thumbnail_20200205_102144 by
thumbnail_20200205_100949 on Flickr
Post by tony2stroke on Feb 5, 2020 12:40:41 GMT 1
thumbnail_20200205_100949 on Flickr Please forgive me if I am wrong, would it not make sense that if all parts are mass produced & are within limits, then there would be different sized shims to accommodate the differences in each part.
Post by earthman on Feb 5, 2020 14:39:50 GMT 1
I know that there are two different design of 4LO calipers period, could there be a mix up with the shims you have??
Post by tony2stroke on Feb 5, 2020 15:15:46 GMT 1
I know that there are two different design of 4LO calipers period, could there be a mix up with the shims you have?? Now you said that, it made me think, I have seen listings for calipers off XJ550 650 750 seca being sold as LC, they have a threaded hole in top caliper mount for a cover. You just don't know whats been changed over the years on old vehicles, almost right, but not quite. Could be bits of different calipers made up.
busby
RD 350 4l0
Post by busby on Feb 5, 2020 20:25:25 GMT 1
If you look in the Haynes manual these are the shim carriers, the exploded diagram shows the shims in between the caliper. I did pose a question a little while ago as to how they are measured, but nobody had a definitive answer
Post by parrott500 on Feb 5, 2020 22:15:19 GMT 1
well i think i need another thin one as when you try and fit the sliding pin into the rubbers it is very hard to push the pin through making it jam the caliper so it wont slide.
Post by Benbeckett on Feb 5, 2020 22:43:01 GMT 1
well i think i need another thin one as when you try and fit the sliding pin into the rubbers it is very hard to push the pin through making it jam the caliper so it wont slide. I will have a look in the morning I have the calipers of my Lc I'm not using yet, I can drop a shim of your not far from me.
Post by tony2stroke on Feb 5, 2020 23:19:25 GMT 1
well i think i need another thin one as when you try and fit the sliding pin into the rubbers it is very hard to push the pin through making it jam the caliper so it wont slide. Does the pin go through without the shim in place, if it doesn't, it could be bad rubbers, also red grease helps, just a couple of thoughts.
Post by shaunthe2nd on Feb 6, 2020 0:06:18 GMT 1
Did you powder coat the other caliper half? If so, powder coating thickness could be the culprit.
Post by parrott500 on Feb 6, 2020 0:28:44 GMT 1
All powder coating removed and new rubber seals fitted with silicone grease, i`m just fixing someone elses mistakes and miss match of parts AAARRRGGGHHHH.
Post by doohanno1 on Feb 6, 2020 0:31:46 GMT 1
Am i dreaming , but should there be another flat shim that sits inside the one's shown above..? 😴🤔
Post by tony2stroke on Feb 6, 2020 0:42:26 GMT 1
If you look in the Haynes manual these are the shim carriers, the exploded diagram shows the shims in between the caliper. I did pose a question a little while ago as to how they are measured, but nobody had a definitive answer This backs that up Doohanno1
Post by earthman on Feb 6, 2020 8:41:08 GMT 1
Yes, I seem to recall a packing piece between them? Is it made from a white material rather than metal? Or maybe thats between the back of the brake pads and their shim, can't remember now.
Post by parrott500 on Feb 8, 2020 20:42:43 GMT 1
Problem solved borrowed from "benbeckett" a pair of calipers and looks like it is a early 4L0 caliper with later mounting bracket thats why it dont go together as it should, also pictures on rd350lc.net to confirm it top marks for info from xaviers website. thumbnail_20200207_122525 on Flickr Etrier4L0-3 on Flickr Etrier4L0-2 on Flickr Etrier 4L0 on Flickr
Post by kwakykarl on Jun 17, 2021 10:27:34 GMT 1
Hi after some shims were do you them from
Post by chrisg on Jun 17, 2021 18:46:47 GMT 1
I have a early 4L0 and it has a little hole and a small spring under the shim. EU import. Are the shims flat? I found if there is any deformation or damage it makes the sliding bracket stiff.
Post by kwakykarl on Jun 18, 2021 7:22:42 GMT 1
My got no shims in at all and rattle bad over bumps
