Post by JonW on Feb 5, 2020 0:44:56 GMT 1
ok, question time for LC2 buffs... Is this brake line run correct? It feels intuitively wrong to me to sweep behind the fork leg as it could get trapped between the fork and the tank... I would think that this should run forwards and not back round the fork tube. So what is going on here? I tried to fit the hose forwards on the splitter but there isnt enough gap as it would hit the headlight/dash bracket... So it had to go further back (which means the tab works as it should to hold the hose) which then means this hose run. weird. This is actually a NOS OEM hose, so i know thats the not the issue... the splitter is a 47x tho. is the OEM LC2 splitter actually different to the 47X? I ask as the LC ones I have are dimensionally the same as the 47X, or at least I thought. so The only thing I can think of is that I haven't fitted any spacers between the bottom of the headlight bracket and the lower triple as I remember discussions where people said they were not fitted when new and were a parts book 'ghost'... maybe that info was wrong? If the bottom was spaced out this hose would fit between the bracket and the tab on the splitter...
Post by oldelsieboy on Feb 5, 2020 8:00:51 GMT 1
Not too clear but looks like it runs in front of the fork leg. OEB
Post by JonW on Feb 5, 2020 8:34:41 GMT 1
Thank Nigel, looks like it runs on the headlight side of the bracket as well.
So... im going to need to space the bracket I guess?
Post by Shytalk on Feb 5, 2020 8:49:28 GMT 1
Jon, there aren’t any spacers (22 on the diagram) the bracket bolts directly onto the bottom yoke. The brake hose goes outside - in front of the fork then behind the headlight bowl, I’m sure Steve will have a picture in his archives.
Post by midlifecrisisrd on Feb 5, 2020 12:47:12 GMT 1
I will have a pic lol but not with my computer
Lc2 goes round front, n1/f1 round the back
Post by JonW on Feb 5, 2020 20:20:07 GMT 1
Thanks guys!
So, Steve, does it also go down the headlight side of the bracket and then go in between the bracket and the tab on the splitter? There isnt much room in there... hmm....
Post by midlifecrisisrd on Feb 5, 2020 20:42:49 GMT 1
Thanks guys! So, Steve, does it also go down the headlight side of the bracket and then go in between the bracket and the tab on the splitter? There isnt much room in there... hmm.... Can't find a detailed pic These are the best I can find at the moment We're from a 4k mile bike that hadn't been taken apart Steve
Post by JonW on Feb 5, 2020 20:56:58 GMT 1
Thanks Steve! Looks like the brake hose stayed on when the bracket came off. I'll have to have another look at that whole area as maybe I missed something obvious in how it threads in.
Post by midlifecrisisrd on Feb 5, 2020 21:17:19 GMT 1
Thanks Steve! Looks like the brake hose stayed on when the bracket came off. I'll have to have another look at that whole area as maybe I missed something obvious in how it threads in. Found one from the front As you say the bracket came off without disturbing the hose Unfortunately that how I got the bike but it must only go one way with the hose in that position Steve
Post by JonW on Feb 5, 2020 22:19:29 GMT 1
Cheers Steve, I'll pull off the bracket and headlight today and have a looksee.
Post by JonW on Feb 6, 2020 12:20:08 GMT 1
Ok sorted now. It just fits in the gap but is very tight. Still if thats what Yam decided then its all good.
Ta for your help guys!
Post by roach3 on Feb 6, 2020 19:56:54 GMT 1
I bought those ghost parts thinking I needed em but obviously I don't why are fowlers selling them they must be for something
Post by midlifecrisisrd on Feb 6, 2020 20:32:51 GMT 1
I bought those ghost parts thinking I needed em but obviously I don't why are fowlers selling them they must be for something It's the picture that is wrong on the original parts pdf They are actually the spacer that goes between the rubbers that mount the bracket to the yoke The rubbers are part 21 on the diagram They are just in the wrong place in the picture Steve
Post by roach3 on Feb 6, 2020 23:08:24 GMT 1
wondered why the clocks moved so much
thnx steve
