Post by veg on Feb 2, 2020 22:51:39 GMT 1
Anyone got one fitted? How do you find the position? Lean angle etc? I have one fitted on my lc I’m running 18 in wheels unfortunately I have a 90 profile rear tyre not an 80.wonder if this is causing the poor positioning.
Post by donkeychomp on Feb 2, 2020 23:29:53 GMT 1
Got a pic?
Post by midlifecrisisrd on Feb 3, 2020 9:44:14 GMT 1
Mine toppled but luckily no bodywork fitted and go pipes on the other side so got away with it
Post by veg on Feb 3, 2020 10:38:31 GMT 1
I am having a problem with Tapatalk loading pics but there are some in the build thread Alex Thanks Steve I’m wondering if it’s due to non std wheels etc I’m really not 100% happy with it always concerned it’s going to go over so I’ll need to replace it but as I have nk rearsets it’s more awkward. Guessing you’ve replaced it Steve?
Post by 4l04ever on Feb 3, 2020 11:19:47 GMT 1
If the back end is jacked up by having fatter tyres or longer shock, then you will need a longer side stand. I had mine cut and a piece of tube welded in to make it a bit longer. NK makes nice stainless side stands, so could be made to the correct length for you.
Post by midlifecrisisrd on Feb 3, 2020 13:50:51 GMT 1
I am having a problem with Tapatalk loading pics but there are some in the build thread Alex Thanks Steve I’m wondering if it’s due to non std wheels etc I’m really not 100% happy with it always concerned it’s going to go over so I’ll need to replace it but as I have nk rearsets it’s more awkward. Guessing you’ve replaced it Steve? No it's still on it. It wasn't the length that was the problem. I think it is because the foot is bent in it has less offset so loses stability I told the New owner about it and warned it should only be left on level ground with the steering turned to the right. If to the left it rolls forward easily and the stand flips up Steve
Post by veg on Feb 3, 2020 14:36:24 GMT 1
Steve thanks buddy, i will try it that way but probably will exchange it.
