Post by andy748 on Feb 1, 2020 10:34:35 GMT 1
Gents, can i test the output of the charging system from the stator while running? Do i do each white wire separately and if so what reading should i be looking for? Many thanks, Andy.
Post by marrcel on Feb 1, 2020 21:35:38 GMT 1
Measure the voltage of the battery. Say12,6V Start engine idle say 13v Rev it you can see 14v
If you test the coils with the white wires. You will measure the resistance of each coil. When it is not running offcourse
Post by andy748 on Feb 1, 2020 23:07:51 GMT 1
Thanks Marcel, i get nothing, so i have bought a new stator, at least i know it will be good for a few years. Andy.
Post by marrcel on Feb 1, 2020 23:30:29 GMT 1
Check the rectifier
