Post by parrott500 on Jan 31, 2020 20:49:55 GMT 1
First run of motor after a apparent full rebuild, found loose flywheel nut and stripped stator mounting bolts, going to strip off clutch cover tomorrow to check primary drive & clutch nuts and find where this noise is coming from.
Click on pic for video
20200131_170014 by on Flickr stripped bolt by on Flickr
Post by nobby62 on Jan 31, 2020 21:15:27 GMT 1
What with the issues you have already mentioned along with the rattly starter....I would be tempted to do a complete strip and investigation to the rest of the rebuild.. You say “apparent” is this a bike you have just bought
Post by parrott500 on Jan 31, 2020 22:12:34 GMT 1
It`s a friends bike thats he`s just bought and I have the job of fixing it. so i`ll open it up tomorrow and do somemore checks and go from there hopefully no more suprises and it`s just a defective kickstart mechanism.
Post by 4l04ever on Jan 31, 2020 23:55:29 GMT 1
The kickstart mechanism has not been fitted correctly... The gear on the mechanism is touching the idler gear when the kickstart is in the up position.
Post by 4l04ever on Jan 31, 2020 23:56:24 GMT 1
If you are taking the clutch apart to check it, also check the end of the input shaft with the clutch removed for excess play, as the last two engines I checked were bad...
Post by doohanno1 on Feb 1, 2020 10:33:42 GMT 1
In the immortal words of 'Orange Juice'.. Rip it up and start again..
Post by parrott500 on Feb 3, 2020 19:52:17 GMT 1
All sorted kickstart mechanism was not fitted properly, so now it`s time to repair threads to hold the stator plate to crankcases.
Post by steeley on Feb 3, 2020 21:37:46 GMT 1
Sorry , could not get video to run . Ok for folks who are tech minded .
