Post by arrow on Jan 26, 2020 18:52:04 GMT 1
No throttle = no oil. Would take a long and steep hill to starve the oil supply to ensure a seizure though. If the oil is already mixed in the tank, then surely it will be over oiling rather than no oil? I'm confused now. Going down a hill at 6000rpm with the throttle shut, the motor is only getting the same fuel AND oil that it would be getting at idle revs, basically. The only thing it's getting a bit more of in this situation is air.
Post by steven on Jan 26, 2020 18:52:58 GMT 1
Post by russpuss on Jan 26, 2020 18:53:58 GMT 1
If the oil is already mixed in the tank, then surely it will be over oiling rather than no oil? I'm confused now. Going down a hill at 6000rpm with the throttle shut, the motor is only getting the same fuel AND oil that it would be getting at idle revs, basically. Makes sense now, does that mean it does the same with a pump fitted also then?
Post by steven on Jan 26, 2020 18:54:06 GMT 1
.... oh and plenty big plastic syringes on evilbay too.
Post by midlifecrisisrd on Jan 26, 2020 18:56:01 GMT 1
Going down a hill at 6000rpm with the throttle shut, the motor is only getting the same fuel AND oil that it would be getting at idle revs, basically. Makes sense now, does that mean it does the same with a pump fitted also then? No, because the pump is running faster as the engine is driving it at higher revs Steve
Post by russpuss on Jan 26, 2020 18:57:29 GMT 1
Makes sense now, does that mean it does the same with a pump fitted also then? No, because the pump is running faster as the engine is driving it at higher revs Steve Ah, well it’s all making sense now. I’ll blow it up without a pump!
Post by arrow on Jan 26, 2020 18:58:28 GMT 1
Makes sense now, does that mean it does the same with a pump fitted also then? No, because the pump is running faster as the engine is driving it at higher revs Steve Correct Sir.
Post by arrow on Jan 26, 2020 19:02:04 GMT 1
According to Yamaha, of the Autolube system, the engine is always lubricated correctly in every riding scenario.
Post by earthman on Jan 26, 2020 19:21:25 GMT 1
My bike is premix and i mix the oil to how i drive that particular day. Most of the long rides are with the cafe racer crowd and i would on average use 3 to 4 tanks of fuel. I then carry the oil with me in a rucksack. When Bimbling around with the cafe racers i tend to use a premix ratio of 40:1. This is due to the slow speed of the rides and if the premix ratio is lower people behind me start complaining about the smoke and the smell they have in their Jackets If i'm going out for a proper ride i tend not to go so far and usually put a 1 litre bottle of oil under the seat and make sure the tank is full before i set off. I then make sure the premix ratio is 1:28 this ratio is for really flogging the bike. Oil seems to be more and more difficult to buy once under way, thats why i always take my oil with me. To get the premix ratio correct i use an app which is on my telephone. i just select the premix ratio and type in the amount of fuel I've just tanked, the app automatically tells you how much oil to add. On the side of the bottle there are marks usually at 100ml. It is not rocket science so a little too much or a little less is not going to destroy your engine. Just make sure you leave some space in the fuel tank for the oil you have to add. Once the oil is added you have to swish the fuel around to mix it, this is easier when the tank is not brimmed. How do you manage to fit a 1 litre bottle under the seat? It is a 4LO you are talking about?? In the tail section of mine a 500ml bottle of Slime (puncture sealant) just about fits, I also have the toolkit, spark plugs and other odds and ends in there.
Post by beardy on Jan 26, 2020 19:48:50 GMT 1
Did think the same thing but not enough to question it
Post by nobby62 on Jan 26, 2020 20:45:12 GMT 1
If the oil is already mixed in the tank, then surely it will be over oiling rather than no oil? I'm confused now. Going down a hill at 6000rpm with the throttle shut, the motor is only getting the same fuel AND oil that it would be getting at idle revs, basically. The only thing it's getting a bit more of in this situation is air. What carries the fuel/oil mixture?...... air of course, so more air, more mixture
Post by arrow on Jan 26, 2020 20:55:52 GMT 1
Going down a hill at 6000rpm with the throttle shut, the motor is only getting the same fuel AND oil that it would be getting at idle revs, basically. The only thing it's getting a bit more of in this situation is air. What carries the fuel/oil mixture?...... air of course, so more air, more mixture Yes, but when the throttle is shut the main jet is shut off and the pilot cannot supply enough fuel at 6000rpm for example.
Post by Tobyjugs on Jan 26, 2020 20:59:14 GMT 1
My bike is premix and i mix the oil to how i drive that particular day. Most of the long rides are with the cafe racer crowd and i would on average use 3 to 4 tanks of fuel. I then carry the oil with me in a rucksack. When Bimbling around with the cafe racers i tend to use a premix ratio of 40:1. This is due to the slow speed of the rides and if the premix ratio is lower people behind me start complaining about the smoke and the smell they have in their Jackets If i'm going out for a proper ride i tend not to go so far and usually put a 1 litre bottle of oil under the seat and make sure the tank is full before i set off. I then make sure the premix ratio is 1:28 this ratio is for really flogging the bike. Oil seems to be more and more difficult to buy once under way, thats why i always take my oil with me. To get the premix ratio correct i use an app which is on my telephone. i just select the premix ratio and type in the amount of fuel I've just tanked, the app automatically tells you how much oil to add. On the side of the bottle there are marks usually at 100ml. It is not rocket science so a little too much or a little less is not going to destroy your engine. Just make sure you leave some space in the fuel tank for the oil you have to add. Once the oil is added you have to swish the fuel around to mix it, this is easier when the tank is not brimmed. How do you manage to fit a 1 litre bottle under the seat? It is a 4LO you are talking about?? In the tail section of mine a 500ml bottle of Slime (puncture sealant) just about fits, I also have the toolkit, spark plugs and other odds and ends in there. It's slightly modified. I have fitted the battery there as well. Im just charging my camera battery then i will post a picture for you. Good thing is you don't notice it
Post by Tobyjugs on Jan 26, 2020 21:15:38 GMT 1
The oil pump subject is quite interesting. It definitely always delivers oil, but in my opinion the action is a bit delayed. Have you ever noticed the snail trail of oil on the bottom of your carbs and inlet manifold in a standard set up? I believe the oil doesn't get truly mixed until the oil trail hits the reed blocks and petals.
Personally i prefer an oil pump but with a good oil there is still a lot of lubrication in there to protect your rings and piston.
Post by steve h on Jan 26, 2020 21:48:45 GMT 1
That snail trail will have a lot to with the engine coming to a stop. As it is very nearly stopped there will still be oil being pumped, but due to the low induction pressure it will be unable to reach the crankcases.
Post by tipfinchy on Jan 26, 2020 21:56:56 GMT 1
My bike is premix and i mix the oil to how i drive that particular day. Most of the long rides are with the cafe racer crowd and i would on average use 3 to 4 tanks of fuel. I then carry the oil with me in a rucksack. When Bimbling around with the cafe racers i tend to use a premix ratio of 40:1. This is due to the slow speed of the rides and if the premix ratio is lower people behind me start complaining about the smoke and the smell they have in their Jackets I have seen strawberry scented 2T oil for sale , might have less complaints mart
Post by markhoopy on Jan 26, 2020 21:58:33 GMT 1
Anyone with space issues on their bike for carrying bottles of oil for premix could always consider fitting a rack and fibreglass top-box. Also handy for carrying your tea home from the chippy should advancing years have caused midriff tightness on your jacket/leathers/whatever.
Post by russpuss on Jan 26, 2020 21:59:45 GMT 1
Anyone with space issues on their bike for carrying bottles of oil for premix could always consider fitting a rack and fibreglass top-box. Also handy for carrying your tea home from the chippy should advancing years have caused midriff tightness on your jacket/leathers/whatever. Funnily enough, I’ve got a top rack for mine, will be powdercoated and test fitted to see if it’s silly enough!
Post by Tobyjugs on Jan 26, 2020 22:09:53 GMT 1
Here is the pictures for the oil bottle space. It wasn't made with that in mind it was just a handy bit of space. Hi Steve yes thats a good reason.
Post by russpuss on Jan 26, 2020 22:28:46 GMT 1
Here is the pictures for the oil bottle space. It wasn't made with that in mind it was just a handy bit of space. Hi Steve yes thats a good reason. Think I’ll struggle as my exhausts go up there, I’m off to see Norbo tomorrow to buy bits so will look at machined original to take pump to see what options I have, maybe see if Dean at Billet world cans modify a billet case for me
Post by steve h on Jan 26, 2020 23:15:22 GMT 1
Anyone with space issues on their bike for carrying bottles of oil for premix could always consider fitting a rack and fibreglass top-box. Also handy for carrying your tea home from the chippy should advancing years have caused midriff tightness on your jacket/leathers/whatever. HAHAHAHAHAHAHA!!
Post by earthman on Jan 26, 2020 23:45:49 GMT 1
Anyone with space issues on their bike for carrying bottles of oil for premix could always consider fitting a rack and fibreglass top-box. Also handy for carrying your tea home from the chippy should advancing years have caused midriff tightness on your jacket/leathers/whatever. Funnily enough, I’ve got a top rack for mine, will be powdercoated and test fitted to see if it’s silly enough! Have you got a top box for it too? Would love to see some photos of them on an LC,..it's not going to look right I'm sure.
Post by russpuss on Jan 26, 2020 23:52:41 GMT 1
Funnily enough, I’ve got a top rack for mine, will be powdercoated and test fitted to see if it’s silly enough! Have you got a top box for it too? Would love to see some photos of them on an LC,..it's not going to look right I'm sure. Yep top box too, I’m sure it will look the dogs
Post by arrow on Jan 27, 2020 0:01:33 GMT 1
Lol! A top box on an LC is like putting a horse box on the back of an Aston Martin!
Post by steve h on Jan 27, 2020 0:03:55 GMT 1
A pro am top box, there's a thought...
Post by pdxjim on Jan 27, 2020 3:00:31 GMT 1
I use premix at 50:1 with Motul 800, jetting is correct for this mix I carry 3 x 100ml oil sample bottles under the duck tail, the oil sample bottles don't leak as they are designed to send, well, oil samples Each bottle is good for 5 litres of fuel, if its 4.8 litres 100ml still goes in As said above premix is not an exact science Yes I get complaints when the bike is smokey I prefer to call the blue smoke coming out the back as rust proofing for those bikes following This essentially what I do, but with a 2.5oz bottle. 2.5oz to a gallon is roughly 50:1. Best not to be messing with your oil ratio too much as this affects your jetting as well, and the diff between say 28:1 and 50:1 is actually quite alot. You may think more oil is "safer", but it really means you're getting only half as much fuel. Best practice is to pick an oil ratio and stick with it. Jet accordingly and all will be well.
Post by pdxjim on Jan 27, 2020 4:10:26 GMT 1
Here is the pictures for the oil bottle space. It wasn't made with that in mind it was just a handy bit of space. Hi Steve yes thats a good reason. What's that swingarm russpuss? Got any clearer pics of it?
Post by muttsnuts on Jan 27, 2020 10:24:57 GMT 1
I have a brand new case with the extended cover and oil pump drive, but they are £325, hence most people avoid them due to the cost
Post by russpuss on Jan 27, 2020 10:48:34 GMT 1
I have a brand new case with the extended cover and oil pump drive, but they are £325, hence most people avoid them due to the cost Money isn’t the problem, it’s just they don’t look trick like the genny side and I’d have to have it stripped and polished, but I may be stuck with that route.
Post by russpuss on Jan 27, 2020 10:49:10 GMT 1
Here is the pictures for the oil bottle space. It wasn't made with that in mind it was just a handy bit of space. Hi Steve yes thats a good reason. What's that swingarm russpuss? Got any clearer pics of it? That’s not my swinger mines a gsxr400rr swinger
