Post by Dixie Dean on Jan 22, 2020 20:00:50 GMT 1
Hi guys anybody recommend a decent metal filler?
Post by looey on Jan 22, 2020 21:30:32 GMT 1
I always use Chemical Metal by Plastic Padding in the yellow metal tins.
It's a nice consistency to fill with and resistant to most things, including fuel.
Post by chrisg on Jan 23, 2020 0:01:56 GMT 1
Hi guys anybody recommend a decent metal filler? Whats it for?
Post by Dixie Dean on Jan 23, 2020 11:13:20 GMT 1
Hi it’s for deep scratches on top of my front master cylinder lid and switch gears.
Post by Deleted on Jan 23, 2020 14:15:11 GMT 1
They aren't a big surface area part so you may well be better off just using a knifing or fine fill putty
New master cylinder lids are available for not much money too, maybe worth a look, by the time you've stripped off all the old paint, cleaned the area filled, sanded, repeat and then etch primed and painted, may not be worth the hassle, the master lid generally has a lot of markings/writing moulded/cut into it that may be problematic in not filling with the putty or metal filler, it would be a lot of work to hoke the putty out of those
Certainly a different story if you are doing a side cover which are worth a bit more
Post by chrisg on Jan 23, 2020 15:35:00 GMT 1
If its going to be for aesthetics and not going to be oil tight, I would suggest plastic padding.
Post by Dixie Dean on Jan 23, 2020 17:56:13 GMT 1
Ok thanks
