Post by pdxjim on Jan 20, 2020 22:56:56 GMT 1
All the same, Mate.
The gold spots have aluminum pistons and the blues have stainless pistons.
That's the only difference AFAIK.
Post by srhiskx on Jan 21, 2020 2:50:36 GMT 1
I have the R6 calipers on my YPVS. Blue dots. They work great with EBC HH pads. I did have to go to a FZ1 master cylinder . The stock YPVS felt weak. The FZ1 has the same blue dots and the master cylinder looks stock on the YPVS.
Post by cb250g5 on Jan 21, 2020 10:23:34 GMT 1
Gold have aluminium pistons. Blue have steel - they do rust. Silver spots are reputed to have stainless pistons, but I have found ordinary pitted steel ones in one I stripped. Unless radial mount, they are all 100mm between centres and interchangeable (bleed nipple and banjo placements differ between models). Easy to strip and rebuild.
Post by zig on Jan 21, 2020 11:50:25 GMT 1
thanks for all the replys guy's....no reason to spend greater money on the R1 Bluespot when the R6 Bluespot are the same caliper happy days then ZiG
Post by chrisg on Jan 21, 2020 14:25:33 GMT 1
Hi, Does anyone know if the blue spot calipers will fit the LC1 ? or is an adaptor bracket needed.
Post by dusty350 on Jan 21, 2020 14:33:01 GMT 1
You need the adapter brackets. No racing do them👍
Dusty🙂
Post by dusty350 on Jan 21, 2020 14:33:54 GMT 1
Nk racing !
Dusty
Post by mellow on Jan 23, 2020 0:32:29 GMT 1
Post by tacky1 on Jan 23, 2020 2:25:43 GMT 1
They fit perfect, NK racing brackets are a perfect fit,
Post by boomflamingo on Jan 23, 2020 14:42:12 GMT 1
Hi Just about to buy some, and do the conversion. My original master cylinder is toast, so should i also buy an R6 master cylinder or
Post by tacky1 on Jan 23, 2020 14:58:38 GMT 1
I used an FZ9 master on mine. Same spot on there for the mirror.
Post by chrisg on Jan 23, 2020 15:33:10 GMT 1
Just a thought? Would the FZ1 front master cylinder be an improvement on the original (twin disc set up) ?
