Post by jazzykecks on Jan 18, 2020 20:41:55 GMT 1
evening all. I’ve just acquired a 4L1 matching frame and engine and plan another hybrid. has anyone got any experience / recommendations other than the usual RGV suspension upgrades?
ideally I’d like a chunky gold ISD front end and banana type swing arm with 17” wheels I’ve looked at TZR / yzr 125 swinger and usd forks as prices are low ( on a strict budget) R6 is an option too.
any comments welcomed. ta.
Post by risolc on Jan 18, 2020 21:55:15 GMT 1
I had a Yzf125 swingarm modified but fitted great but didn’t look how I thought it would.
Post by donkeychomp on Jan 19, 2020 0:38:52 GMT 1
YZF fits both ends with minor tweaks. I have Cagiva Mito 125 front (straight swap) and rear (not very easy at all!).
Post by dusty350 on Jan 19, 2020 10:04:18 GMT 1
You are very limited regards the swingarm/wheel combo. Nearly everything needs modding, to varying degrees, to fit in the narrow Lc frame, which is approx. 200mm across the pivot. Lots of guys use Rgv arms, but they are longer by approx. 4"; 20191227_111504 by dusty miller, on Flickr They are a "marmite" swingarm for most - some don't mind the extended look of the bike, others are not so keen ! It will change the handling characteristics of the bike, and the mod for the shock can be an expensive thing to get done. A lot of the more modern swingarms don't have any top loops like the Lc needs, as the Ypvs style upright shock became more popular through bikes like the Tzr/Kr1/s/Rgv etc, and the more modern, bigger bikes often need the frame widened to get a swingarm in and chain run anywhere near. I'm pretty sure a Tzr250 rear wheel will go into an Lc swingarm with a couple of simple spacers - I think Rich on here has done that, and Jon too ? Metmachex will make you a lovely box section swingarm to the correct dimensions for the Lc, with slotted chain adjusters, chain slider etc for about £500 brand new, which I think is a hard price to beat when you consider what you may end up spending on a second hand arm that needs modding/painting/polishing/new bearings etc. Front ends are much easier normally !! Just my opinion Dusty
Post by jon on Jan 19, 2020 10:32:52 GMT 1
Dusty, your memory is partially correct. I do have a TZR rear wheel in my LC (3.5” wide) although I have a converted swingarm from a TZR 2MA. rdlccrazy.proboards.com/post/220728You can see it’s in between the length of an LC and RGV. Jon
Post by Tobyjugs on Jan 19, 2020 10:51:18 GMT 1
If You are are a bit patient check all the TZ or racer websites and for sale sites. You can find Ally swing arms from TZ's which will need minor modification and is the same or very close to the standard wheel base of an LC. As you can see the wheel base is the same, but it does look a bit plain Jane. The construction around the two pivot points for the chassis and the shock is very strong. Similar to the Metmachex TZ arm
Post by veg on Jan 19, 2020 14:52:44 GMT 1
Would love a tz swing arm, keep looking
Post by Tobyjugs on Jan 19, 2020 21:25:35 GMT 1
Would love a tz swing arm, keep looking Hi Veg the last pm i sent you had a link with one for sale.
Post by veg on Jan 19, 2020 21:36:01 GMT 1
Tony that was a link to lightweight rims? And it would never open always said can’t reach server. Bugger.
Post by Tobyjugs on Jan 19, 2020 22:02:49 GMT 1
Tony that was a link to lightweight rims? And it would never open always said can’t reach server. Bugger. Yes i just checked and your right it didn't open
Post by veg on Jan 19, 2020 22:16:08 GMT 1
Will have a look got your pm thanks mate 👍
Post by veg on Jan 19, 2020 22:18:20 GMT 1
Post by pdxjim on Jan 20, 2020 1:46:20 GMT 1
Post by JonW on Jan 20, 2020 12:29:45 GMT 1
twostrokebrit on the RZRD500 forum did something with a YZ IIRC Jim.
Post by oldelsieboy on Jan 20, 2020 19:57:33 GMT 1
Post by pdxjim on Jan 20, 2020 20:11:50 GMT 1
Cheers for that, and curses to Photofcukit.
Post by jazzykecks on Jan 20, 2020 21:04:39 GMT 1
Thanks Fellas. Any other comments much appreciated.
Post by LC_BOTT on Jan 21, 2020 9:25:54 GMT 1
Post by dusty350 on Jan 21, 2020 9:34:43 GMT 1
Post by Gitram on Feb 2, 2020 13:32:28 GMT 1
the yz 250 arm is a touch shorter than the 465 arm. I had a 465 one in an 250LC frame until some fud stole the bike, i got it back but the arm was last seen in a scrappies..on the plus side, the capacity had risen by 100 cc.. The mount on the frame was moved a bit further forwards and an rd125 shock was used as well to get the ride height back. I bought a 250 and a 465 arm from a MX breaker years ago to replace the stolen one but need a rd shock to sort it all out.. the mx swingarm is a bit narrower so i had spacers made up but haven't got any more done.. bike is about 150 miles from where i live so ain't too high on the priority project list.. oh and there was a notch cut out of the arm to allow the chain to run freely. unlike the LC swingarm there was no flex in the alloy yz one
marti
