Post by noonster on Jan 12, 2020 21:18:43 GMT 1
Just restored a 81 rd350lc,engine rebuild.
Started bike up for the first time in 10years.
issues
will only tick over 3-4 thou revs with choke on,soon as i push it in it races then falls off and stalls. thought i got with removing carbs and cleaning slow jet out.
Its better,but not quite there,also found fuel leaking out of cab bowl over flow, so wonder if floats sticking.
Also when i set the throttle cable up on the pump, when the bike was ticking over the pulley hardly move in or out,if i adjust the cable above the pump i can see it working better, pulsing. But then when the bike is stood and i turn to full throttle the mark on the pulley is not inline then with the pin.
Its a proper Yamaha cable, but the carbs are off a 31k not 4LO-001
So bikes ticking over a bit better,got it to tic at 2000rev with choke in, notice fuel dipping out of bowl pipe
pump pulley not in lign
Any ideas please
Post by rigga on Jan 12, 2020 22:32:12 GMT 1
Have you had the pump rebuilt and shimmed?
Post by shaunthe2nd on Jan 12, 2020 22:41:15 GMT 1
I suspect its more than the oil pump, could be air leak somewhere. To eliminate pump, test run it on pre-mix via a temp tank and take it from there.
Post by rigga on Jan 12, 2020 23:28:56 GMT 1
Possibly more than one issue, my comment was in relation to the pump not pulsing on tickover.
Post by noonster on Jan 12, 2020 23:30:46 GMT 1
using a fuel bottle.
pumps not been re shimmed, for whats its worth it was a runner before being stripped the bike
Post by shaunthe2nd on Jan 13, 2020 0:12:38 GMT 1
Sort one problem at a time I'd suggest. Send oil pump to Arrow for his magic.
In meantime use the fuel bottle with pre-mix to set up carbs. Check for air leaks, check main and pilot jetting, float heights correct, needle settings correct, carbs balanced, ensure float bowls not been switched over, choke circuit is clean, air correction circuit clean (balls out), air box and filter clean.
Good luck with it.
Shaun.
Post by muttsnuts on Jan 13, 2020 10:33:19 GMT 1
you said "Its a proper Yamaha cable, but the carbs are off a 31k not 4LO-001" - so have you blocked off the vacuum take off on the RHS carb ?
Post by rigga on Jan 13, 2020 12:01:54 GMT 1
you said "Its a proper Yamaha cable, but the carbs are off a 31k not 4LO-001" - so have you blocked off the vacuum take off on the RHS carb ? Well spotted (as expected)
Post by muttsnuts on Jan 13, 2020 20:46:16 GMT 1
you said "Its a proper Yamaha cable, but the carbs are off a 31k not 4LO-001" - so have you blocked off the vacuum take off on the RHS carb ? Well spotted (as expected) was it a test, did I pass
Post by rigga on Jan 13, 2020 22:42:06 GMT 1
Well spotted (as expected) was it a test, did I pass I don't think I could set a test you'd fail to be honest ...
Post by JonW on Jan 13, 2020 23:52:19 GMT 1
No mention of a pressure test on the engine either. Did you do one?
