Post by dusty350 on Dec 15, 2019 20:55:08 GMT 1
Looking lovely Pete. Regards the mudguard, the rear part bolts to the fork bottom on the inside of the cast boss on the forks - saves stressing the mudguard Keep up the good work Dusty
Post by petehodges on Dec 15, 2019 21:03:16 GMT 1
Looking lovely Pete. Regards the mudguard, the rear part bolts to the fork bottom on the inside of the cast boss on the forks - saves stressing the mudguard Keep up the good work Dusty Thanks dusty yer I did know about mudguard just put it on for looks mate π
Post by dusty350 on Dec 15, 2019 21:08:37 GMT 1
Ah, ok Have you got the brace to fit inside the mudguard ? The Rg125 brace fits - may be a cheaper alternative second hand if you need one, but only has one loop for a brake line as the 125 is a single disc. Dusty
Post by petehodges on Dec 15, 2019 21:10:44 GMT 1
So I put the callipers on today but not really happy with the bolts They look rubbish, Iβm bloody rubbish at ordering nuts& bolts allways the wrong bloody sizes , so my next question I know these are a different thread sizes ? & also whereβs best too look for some nice new ones π
Post by petehodges on Dec 15, 2019 21:12:45 GMT 1
Ah, ok Have you got the brace to fit inside the mudguard ? The Rg125 brace fits - may be a cheaper alternative second hand if you need one, but only has one loop for a brake line as the 125 is a single disc. Dusty Dusty I didnβt know it had a brace ? Better get looking for one βοΈ thanks for that , never got involved with Rgv stuff before
Post by midlifecrisisrd on Dec 15, 2019 21:18:18 GMT 1
Post by dusty350 on Dec 15, 2019 21:40:17 GMT 1
The brace fits perfectly underneath the muddie, so you don't see it apart from where the 2 brake line loops appear from underneath the mudguard; 20191215_203155 by dusty miller, on Flickr The small bolt locates with a threaded hole in the brace each side, and the bigger allen bolt below it goes through the fork mount and into a captive nut on each side of the brace. Dusty
Post by petehodges on Dec 16, 2019 8:29:51 GMT 1
Thanks Steve for that mate π
Post by morgy on Dec 16, 2019 12:44:58 GMT 1
I think i have some RGV250 VJ 22 caliper bolts if you want some... Will donate to your project if you cover postage.. I will have a look for them if you want them...
Post by mak595 on Dec 16, 2019 15:37:13 GMT 1
Got to love this forum for the knowledge and general helpfulness, great build BTW
Post by petehodges on Dec 17, 2019 9:19:16 GMT 1
I think i have some RGV250 VJ 22 caliper bolts if you want some... Will donate to your project if you cover postage.. I will have a look for them if you want them... Morgue thatβs really kind of you mate , If your still ok with this Iβll take you up on your offer & of course Iβm happy too pay for all the bolts & postage Pete π
Post by petehodges on Dec 17, 2019 9:24:27 GMT 1
Got to love this forum for the knowledge and general helpfulness, great build BTW Yes arenβt there some great lads on this forum would of never got this or my old lc off the ground without this forum , all your thoughts & knowledge is very much appreciated π & also thanks to those that nip out too there garage to post me pics of stuff really kind Thank you so much Pete π
Post by petehodges on Dec 17, 2019 23:56:27 GMT 1
Done a couple of jobs tonight so as for the clock bracket How does it sit ? Iβm sure when took it off it was on of the rubber mounts , but look though build pics I see others mount them under neath ?
Post by midlifecrisisrd on Dec 18, 2019 9:12:58 GMT 1
Underneath
Post by LC_BOTT on Dec 18, 2019 12:05:38 GMT 1
Post by dusty350 on Dec 18, 2019 17:03:38 GMT 1
Underneath as standard regards the clock bracket, but they can be mounted on top if you want to sit the clocks and headlight higher Dusty
Post by shaunthe2nd on Dec 19, 2019 2:28:42 GMT 1
Under for sure. It's a pet hate if mine to see them mounted above!
Post by morgy on Dec 19, 2019 8:39:05 GMT 1
I think i have some RGV250 VJ 22 caliper bolts if you want some... Will donate to your project if you cover postage.. I will have a look for them if you want them... Morgue thatβs really kind of you mate , If your still ok with this Iβll take you up on your offer & of course Iβm happy too pay for all the bolts & postage Pete π I had a dig and found them the other day They need a polish up but threads look good... Best to pm me your Address and i will fire them out...
Post by morgy on Dec 19, 2019 8:47:48 GMT 1
As said above, under on my spondon yokes, You might need a couple of small spacers under the Barrel/lock mechanism if you want the lock working on the Key. IMG_2868 by mark morgan, on Flickr
Post by petehodges on Dec 19, 2019 9:18:08 GMT 1
As said above, under on my spondon yokes, You might need a couple of small spacers under the Barrel/lock mechanism if you want the lock working on the Key. IMG_2868 by mark morgan, on Flickr Pm sent π
Post by petehodges on Dec 24, 2019 23:20:56 GMT 1
Underneath as standard regards the clock bracket, but they can be mounted on top if you want to sit the clocks and headlight higher Dusty Sorted thanks dusty π
Post by petehodges on Dec 24, 2019 23:23:15 GMT 1
Ok so got a bit more done today
Post by petehodges on Dec 24, 2019 23:24:08 GMT 1
Post by petehodges on Dec 24, 2019 23:24:52 GMT 1
Post by petehodges on Dec 24, 2019 23:26:02 GMT 1
Big thanks too morgy for the brake bolts & old else boy for the mudguard it came up a treat thanks lads ππ Fitted my new clock face as old one the glass cracked π€¬
Post by donkeychomp on Dec 25, 2019 0:30:57 GMT 1
What did you spray that with? Looks really odd...grey and flecks of black in it
Post by petehodges on Dec 25, 2019 9:42:39 GMT 1
What did you spray that with? Looks really odd...grey and flecks of black in it Alex Alex itβs grey primer mate not top coat π
Post by donkeychomp on Dec 25, 2019 23:51:42 GMT 1
Oh thank feck for that!
Post by sidney81 on Dec 26, 2019 8:49:53 GMT 1
Looks lovely ππ
Post by spondon440 on Dec 26, 2019 14:30:31 GMT 1
so a few questions as you can see the forks have no holes for the horn bracket to bolt too , whats the score with this ? do you drill some out or remount them somewhere else , i do really like the horns on an lc on the front but must say i,m not keen on drilling it out. You could have got in touch with me, I made those yokes and I will put those holes in if requested when they are ordered, I may even just start putting them in. You have had those a while I make them different to that now. Andy
