Post by scooter on Dec 6, 2019 13:59:36 GMT 1
hi all are the 250/350lc small end bearings the same for both size of engine
Post by arrow on Dec 6, 2019 15:17:14 GMT 1
No, the 350 bearing is wider or it would have too much end float in the wider piston. Makes you wonder how many 350's out there have the wrong ones fitted, because it's not immediately obvious and they WILL fit. The 350 ones won't fit with 250 pistons. Norbo will have the correct items.
Post by scooter on Dec 6, 2019 20:33:20 GMT 1
cheers arrow for that they use the same rod though
