Earth
Nov 20, 2019 18:42:43 GMT 1
Post by 125lc1dt on Nov 20, 2019 18:42:43 GMT 1
although my DT ran fine in the summer I noticed during the colder weather that the engine will stall at low revs when the horn button is pressed. Wondering if the following could cause it 1) bad earth connection somewhere 2) old horn taking to much amp demand 3) the charging coil is past its sell by date
Earth
Nov 20, 2019 19:16:56 GMT 1
Post by raven13 on Nov 20, 2019 19:16:56 GMT 1
My thought would be its shorting out somewere. check youe switches and connections as well as the earthing points and see where that gets you.
Post by marrcel on Nov 21, 2019 9:08:13 GMT 1
Bad battery
Earth
Nov 21, 2019 20:27:18 GMT 1
Post by 125lc1dt on Nov 21, 2019 20:27:18 GMT 1
Bad battery is as in low charge or faulty ?
Earth
Nov 22, 2019 0:54:46 GMT 1
Post by raven13 on Nov 22, 2019 0:54:46 GMT 1
I wouldnt have thought battery as these bikes will run without one. my rd125lc has had a flat knackered old bAttery on it for 5 years, still starts and rides without any problems
Earth
Nov 22, 2019 2:35:25 GMT 1
Post by JonW on Nov 22, 2019 2:35:25 GMT 1
Well, it does sound like the battery as its worse in cold weather. Else something that shorts more when its damp...
Earth
Nov 22, 2019 10:08:26 GMT 1
Post by 125lc1dt on Nov 22, 2019 10:08:26 GMT 1
I was planning to run an additional earth system as the DT loom only earths via two connections where the coil bolts to the frame. As the frame was powder coated the earth feeds through the bolt threads etc
Earth
Nov 22, 2019 17:20:58 GMT 1
via mobile
Post by lambert on Nov 22, 2019 17:20:58 GMT 1
Well, it does sound like the battery as its worse in cold weather. Else something that shorts more when its damp... Check your fuse mine blow and knocked out the lights after trying another CDI unit... just to make it worse the fuse looked in good condition with no signs of blowing.
Post by marrcel on Nov 29, 2019 23:09:08 GMT 1
I wouldnt have thought battery as these bikes will run without one. my rd125lc has had a flat knackered old bAttery on it for 5 years, still starts and rides without any problems The horn is the biggest consumer of Amperes. Maybe 10A. A bad battery has a high internal resistance. Voltage drops to possible 8volt and the generator coils are working overtime. Try ro start your rd125lc while pushing the horn button. Please post results
Earth
Dec 7, 2019 14:40:27 GMT 1
Post by 125lc1dt on Dec 7, 2019 14:40:27 GMT 1
Tried starting with horn button pushed. Starts okay ? Always have to fiddle with choke a bit when cold to get engine rev cleanly
