Post by peddrotzr on Sept 1, 2020 22:44:39 GMT 1
These bikes are just fabulous !
Post by dusty350 on Sept 2, 2020 6:50:54 GMT 1
Post by cbm on Sept 2, 2020 18:36:14 GMT 1
I’m sure I have seen number 6 before I could be wrong but got a feeling it may be a french bike sponsored by gauloises or similar. I’m pretty sure it’s a 7/750 not a 500. It’s interesting that’s for sure. You could well be right Veg as i have a brain like a sieve 🤪, let me see if I can find out 👍 Apologies Veg, I asked the owner of the actual bike(s) in the picture and he confirmed it's a factory 750. It was one of his others he showed me that was a factory 500 bike, unreal huh .
Post by veg on Sept 2, 2020 19:22:59 GMT 1
Wow no apologies needed buddy. I’m sure I’d seen it before. It’s not the french bike I was thinking of then? I got it wrong as I first thought tz700 but Johnny soon put me right. Whatever it is it’s beautiful and like dusty it would be a lottery bike for me. That’s what I love about here we are all just trying to help each other out. 👍
Post by peddrotzr on Sept 2, 2020 19:45:56 GMT 1
Its great you know the owner! Many thanks for finding out.
its always difficult with these old race bikes as most of them have had a hard life and parts replaced as to the funds allowed.
every day is a school day
Best regards Johnny C.
Post by dusty350 on Sept 3, 2020 7:53:38 GMT 1
Post by oldbritguy on Sept 3, 2020 8:41:47 GMT 1
Oh yes Me likely that very much 👍 John🙂
Post by donkeychomp on Sept 3, 2020 21:39:21 GMT 1
Me too. Are those forks USD made to look like RWU?
Post by Tobyjugs on Sept 4, 2020 0:20:43 GMT 1
The blue and white bike was niggling me as i think i have seen it before. Is it the bike from Jack Middleburg?
Post by veg on Sept 4, 2020 3:07:11 GMT 1
Me too. Are those forks USD made to look like RWU? Alex I believe they are rwu ohlins forks Uber expensive and rare. AC Sanctuary use them in loads of their builds.
Post by dusty350 on Sept 4, 2020 7:06:01 GMT 1
Post by billbott on Sept 4, 2020 8:21:53 GMT 1
Me too. Are those forks USD made to look like RWU? Alex I believe they are rwu ohlins forks Uber expensive and rare. AC Sanctuary use them in loads of their builds. They are indeed. I looked for a set for my GPz9 and decided to refurb the originals....
Post by veg on Sept 4, 2020 8:54:22 GMT 1
I believe they are rwu ohlins forks Uber expensive and rare. AC Sanctuary use them in loads of their builds. They are indeed. I looked for a set for my GPz9 and decided to refurb the originals.... Not cheap are they?
Post by billbott on Sept 4, 2020 9:21:41 GMT 1
They are indeed. I looked for a set for my GPz9 and decided to refurb the originals.... Not cheap are they? More than the bike cost me..!
Post by peddrotzr on Sept 4, 2020 9:39:55 GMT 1
The blue and white bike was niggling me as i think i have seen it before. Is it the bike from Jack Middleburg? Well spotted Tobyjugs
Just found this:- Formerly raced by Team Yamaha IMN (Inter Motor Nederland, the former Yamaha distributor in Holland) www.bonhams.com/auctions/24885/lot/451/
Post by cbm on Sept 4, 2020 11:11:41 GMT 1
Just found this:- Formerly raced by Team Yamaha IMN (Inter Motor Nederland, the former Yamaha distributor in Holland) www.bonhams.com/auctions/24885/lot/451/Spot on Sir, I've been told that particular bike was raced by Jack Middleburg and Boet van Dulmen
Post by dusty350 on Sept 6, 2020 8:21:54 GMT 1
Post by veg on Sept 6, 2020 9:02:41 GMT 1
Super charged single v different I likey 👍
Post by mouse on Sept 6, 2020 10:51:32 GMT 1
SR500?
Mouse
Post by veg on Sept 6, 2020 10:55:59 GMT 1
Sr or Xt mouse suspect sr due to front end not sure of frame though.
Post by Gitram on Sept 6, 2020 12:37:41 GMT 1
Post by dusty350 on Sept 7, 2020 7:39:49 GMT 1
Post by dusty350 on Sept 8, 2020 14:13:54 GMT 1
Post by veg on Sept 8, 2020 14:17:33 GMT 1
The burly humbersider himself 👍. Nice pic.
Post by Tobyjugs on Sept 8, 2020 15:22:55 GMT 1
He makes the bike look tiny
Post by dusty350 on Sept 9, 2020 7:17:45 GMT 1
richb
Post by richb on Sept 9, 2020 10:15:17 GMT 1
Why did they go to the trouble of routing one of the pipes behind the carbs onto the the side of the bike why not have 2 pipes either side. Seems like a lot of extra work plus putting all that hot air off the pipe in the way of cool air being sucked into the carbs when 2 strokes I belive run better in cooler air. It does look good though Rich
Post by veg on Sept 9, 2020 10:27:54 GMT 1
Too wide if you look the pipes under the bike are staggered too keep the width down one pipe is lower than the other 2. By you couldn’t put 2 above 2 as again it’ll impact on ground clearance both height and cornering. One of the problems was the heat interference on the carbs, hence why, The slightly later version had the 2 outer pipes/barrels/carbs reversed so carbs on the outer cylinders stick out the front with pipes rear facing it was still an in line 4, shortly afterwards they went to V4 which lent it self to pipes being in the right place.
Post by dusty350 on Sept 10, 2020 6:59:24 GMT 1
Post by dusty350 on Sept 11, 2020 7:22:51 GMT 1
