Post by dusty350 on Apr 15, 2020 7:36:20 GMT 1
dbgr
Post by dbgr on Apr 15, 2020 9:43:04 GMT 1
Post by mak595 on Apr 15, 2020 12:55:20 GMT 1
Think someones been on the wacky backy
Post by Deleted on Apr 15, 2020 15:08:12 GMT 1
Sorry Dusty
That is no where near your usual standard
What were they thinking
Post by veg on Apr 15, 2020 15:33:15 GMT 1
650 6t pre unit motor check, rickman frame? Check, hit every branch of the ugly tree on the way down oh yes.
Post by oldbritguy on Apr 15, 2020 17:52:02 GMT 1
Don’t think that is a Rickman frame. Looks like a BSA A10 chrome or nickel plated. Triumph pre unit motor though. Straight out of Cheech and Chong with that velour seat. Top “ahem” workmanship with quality tools. You can see the Snap On table knife among the screwdrivers on the floor. Could be a good candidate for “take his tools away” Still, each to his own though 🤪 John
Post by veg on Apr 15, 2020 18:09:30 GMT 1
I did wonder about the frame hence ? New it wasn’t a triumph having owned a few bonnies, it’s also single carb head, thought the A10 was slightly different but I think it’s a bsa rear hub? Whatever it is it feckin rank
Post by donkeychomp on Apr 15, 2020 22:52:36 GMT 1
Sadly I have now seen this and it's firmly embedded in my memory. Good thing is every time I learn something new, something else gets shoved out of my brain so I shall consult a botlle of Merlot...
Post by dusty350 on Apr 16, 2020 7:30:50 GMT 1
Post by Deleted on Apr 16, 2020 14:07:00 GMT 1
Much better Dusty, even if it is a Kwaka lol
Post by donkeychomp on Apr 16, 2020 21:48:48 GMT 1
Hell yes!
Post by oldbritguy on Apr 17, 2020 7:51:22 GMT 1
That Suzi motor looks just right at home in there
Lovely job
Post by dusty350 on Apr 17, 2020 7:54:28 GMT 1
Post by sbscnor on Apr 17, 2020 10:56:17 GMT 1
Ah that's much better normal service resumed Dusty :-)
Post by dusty350 on Apr 18, 2020 9:09:26 GMT 1
Post by oldbritguy on Apr 18, 2020 9:37:18 GMT 1
That is very nice indeed! 3 cylinders?
Post by dusty350 on Apr 18, 2020 10:23:54 GMT 1
Yep, 3 cylinders with the centre one reversed.
Dusty🙂
Post by jon on Apr 18, 2020 10:47:54 GMT 1
Regardless of the major modifications, one simple one I quite like is the indicators (late YPVS?). The LC rear subframe on my latest build has had the usual mod of removing the indicator stalks. Rather than repair back to standard and use LC indicators, this might be a nice option. Jon
Post by zig on Apr 18, 2020 10:55:46 GMT 1
Regardless of the major modifications, one simple one I quite like is the indicators (late YPVS?). The LC rear subframe on my latest build has had the usual mod of removing the indicator stalks. Rather than repair back to standard and use LC indicators, this might be a nice option. Jon I like the way he has used the standard LC stator case on the YPVS engine.....I remember asking in a post a while back could this work but nobody having a solution ? ZiG
Post by jon on Apr 18, 2020 11:00:40 GMT 1
Regardless of the major modifications, one simple one I quite like is the indicators (late YPVS?). The LC rear subframe on my latest build has had the usual mod of removing the indicator stalks. Rather than repair back to standard and use LC indicators, this might be a nice option. Jon I like the way he has used the standard LC stator case on the YPVS engine.....I remember asking in a post a while back could this work but nobody having a solution ? ZiG This has been done many times in the past, as the profile is the same so a straight swap. From memory the bolt lengths were different though? Jon
Post by zig on Apr 18, 2020 11:09:53 GMT 1
I like the way he has used the standard LC stator case on the YPVS engine.....I remember asking in a post a while back could this work but nobody having a solution ? ZiG This has been done many times in the past, as the profile is the same so a straight swap. From memory the bolt lengths were different though? Jon Hi Jon....thanks for that , I've recently just bought a YPVS for a hybrid project £1000 !! + I have a 250lc which I have finished BUT both at my workplace so cant give it a try ZiG
Post by dusty350 on Apr 19, 2020 8:07:42 GMT 1
Post by dusty350 on Apr 20, 2020 8:06:14 GMT 1
Post by donkeychomp on Apr 20, 2020 21:43:28 GMT 1
Is the chain meant to be like that??
Post by Tobyjugs on Apr 20, 2020 22:57:32 GMT 1
Is the chain meant to be like that?? Alex Probably, take a look at the line between front sprocket swing arm pivot and rear wheel spindle. I think the angle of the rear shock looks extreme.
Post by peddrotzr on Apr 21, 2020 7:12:08 GMT 1
Post by dusty350 on Apr 21, 2020 8:11:03 GMT 1
Sweet looking bike I've always loved the look of those Morini engines. Dusty
Post by dusty350 on Apr 21, 2020 8:12:02 GMT 1
Post by veg on Apr 21, 2020 9:22:44 GMT 1
That’s a gorgeous looking wee vee
Post by dusty350 on Apr 22, 2020 7:19:05 GMT 1
