Post by mattb68 on Oct 22, 2019 20:01:28 GMT 1
Hi all I’m planning stripping my 250LC down over the winter and getting the frame painted and have a couple of questions ?
Powder coat or paint. Should the frame be gloss or semi gloss. It’s a german import is it easy to remove the steering lock barrel and refit after paint. Swing arm pin I’ve seen on yam bits an upgrade are they any good.
no doubt I will have some more questions once I start stripping it down
Cheers Matt
Post by stusco on Oct 22, 2019 21:12:23 GMT 1
Post by russpuss on Oct 22, 2019 21:17:03 GMT 1
I cut and welded the lock up and fabbed a uk lip and swapped ignitions then had mine powdered white as it’s different! Not sure about anything from Shambits I’m afraid.
