Post by oldelsieboy on Oct 12, 2019 16:29:44 GMT 1
This brace came fitted to a pair of LC2 forks but it has 54 stamped on the underneath of the collars. On closer inspection it also has 58 scratched next to the 54. The lower diameter measures 58mm but the LC2 dust seal is a loose fit to the top section, whereas an LC seal fits perfectly. Anyone else have a similar issue or is this an LC brace that has been machined to fit LC2 forks. OEB
Post by 4l04ever on Oct 12, 2019 16:45:38 GMT 1
Not seen one before, but that has been messed with and now it is not a good option for LC or LC2...
Post by 4l04ever on Oct 12, 2019 16:49:31 GMT 1
..best option is probably to get a piece of tube machined 58mm OD and 54mm ID, then cut in half and glue in to reduce them back to 54mm.
Post by donkeychomp on Oct 12, 2019 23:15:18 GMT 1
That looks very very wrong to me.
