Post by Norbo on Oct 11, 2019 16:44:50 GMT 1
Well it looks like Koyo have stopped doing the bearing for out cranks . so its Tai bearings only now . Lucky i have a reasonable stock for a few more of my cranks but then they will be no more . The tai ones you can get now are Ok not like 20 years back but do like to use jap if possible but like it or not if you cant get them you cant get them simple as that .
Post by Tobyjugs on Oct 11, 2019 20:47:56 GMT 1
I don't think it's such a problem if you know the right engineers.
Post by Norbo on Oct 12, 2019 7:51:24 GMT 1
They are not making any more its as simple as that not unless an order of 2000 is made
Post by oldbritguy on Oct 12, 2019 8:31:42 GMT 1
What about gearbox bearings Norbo. Will they still be available from Koyo?
Post by pdxjim on Oct 12, 2019 8:48:02 GMT 1
No problem getting proper Japanese Nachi bearings here. Koyo certainly sounds better than Notchy, tho, that’s for sure
Post by JonW on Oct 12, 2019 9:23:59 GMT 1
I guess Yam will still supply Koyos as OEMs as they can meet the MOQ, but hearing you Norbo, your £14 each is a lot cheaper than any Yam dealer.
Post by Norbo on Oct 13, 2019 15:48:53 GMT 1
Yes yam still have them in stock at a fortune and engine ones are still ok its just the crank ones they are no longer doing . As i say i have anough stock to do several more rthen i just do them with 10 ball as standard there are other makes that can be used but no more Koyo
Post by tsa on Oct 13, 2019 18:02:42 GMT 1
Any quality bearing manufacturer will do as long as it is 6305 C3 clearance Id prefer SKF as it can handle more rpm and load than most.
