Post by JonW on Feb 3, 2020 21:23:50 GMT 1
Have a look at my 251LC thread, I had the opposite problem using the F1 CDI on a BW kill switch bike. I think the CDI wire is red/white but do check my diagram as the info is there.
Post by mak595 on Feb 5, 2020 8:59:40 GMT 1
Have a look at my 251LC thread, I had the opposite problem using the F1 CDI on a BW kill switch bike. I think the CDI wire is red/white but do check my diagram as the info is there. Cheers Jon, all sorted now
Post by mak595 on Apr 7, 2020 15:46:31 GMT 1
Got a bit more done, fairing is on, but I need to sort the front brakes, a new M/C kit has just arrived. Obviously the lockdown has brought it to a halt now as I need to take it for a shake down run once the brakes are done... Got the yamaha decal to put onto the bellypan yet On a better note the 31k passed it's first MOT in many years, I managed a quick 50 mile before the lockdown started and it all seemed ok
Post by Yogi on Apr 7, 2020 15:59:40 GMT 1
Looking good mate 👍
Post by Deleted on Apr 7, 2020 17:25:33 GMT 1
Hi Mak
Looking real good indeed
Quick query when you put the headlight fairing on did you have droopy indicators at the front, if so how did you correct them
Only ask as mine droop downwards and my headlight is lightly skew whiff, however the fairing is level
Cheers
Howard
Post by midlifecrisisrd on Apr 7, 2020 17:34:42 GMT 1
Nice pair 😜
Post by mak595 on Apr 7, 2020 17:46:03 GMT 1
Hi Mak Looking real good indeed Quick query when you put the headlight fairing on did you have droopy indicators at the front, if so how did you correct them Only ask as mine droop downwards and my headlight is lightly skew whiff, however the fairing is level Cheers Howard i found i had to tweek the indicator mount slightly as one side was a bit angled down.... I bolted a long bolt and washers into the indicator mount, then put a hollow bar on the bolt and moved it up a bit, this was with the fairing off
Post by mak595 on Apr 10, 2020 15:51:47 GMT 1
Got some petrol from the garage because we needed milk, runs ok on the drive but noisy from the clutch area.. I didn't use any clutch rubbers, does that cause the noise?
F1 Bitsa
Apr 10, 2020 16:24:05 GMT 1
via mobile
Post by midlifecrisisrd on Apr 10, 2020 16:24:05 GMT 1
I've never noticed much difference with rubbers in/out
I've had noisy ones for no reason
Also had very low mile bikes that clatter
Post by mak595 on Apr 10, 2020 18:41:37 GMT 1
I've never noticed much difference with rubbers in/out I've had noisy ones for no reason Also had very low mile bikes that clatter Steve Weird, my 31k is quiet as a mouse compered to the F1. Got a vid but can you d/l them with tapatalk?
F1 Bitsa
Apr 10, 2020 18:48:14 GMT 1
via mobile
Post by midlifecrisisrd on Apr 10, 2020 18:48:14 GMT 1
Don't think so
You would need to use a hosting site for video
Post by mak595 on Apr 10, 2020 18:51:05 GMT 1
Hopefully this utube will work
Post by mak595 on Apr 11, 2020 16:03:39 GMT 1
I've never noticed much difference with rubbers in/out I've had noisy ones for no reason Also had very low mile bikes that clatter Steve Steve, does mine sound ok? Bit paranoid with it being a lot louder than my 31k
F1 Bitsa
Apr 11, 2020 16:53:23 GMT 1
via mobile
Post by midlifecrisisrd on Apr 11, 2020 16:53:23 GMT 1
I've never noticed much difference with rubbers in/out I've had noisy ones for no reason Also had very low mile bikes that clatter Steve Steve, does mine sound ok? Bit paranoid with it being a lot louder than my 31k Noisy but I've heard worse Steve
Post by andy748 on Apr 11, 2020 18:19:33 GMT 1
Sounds similar to mine Mak, i've changed the basket, cush rubbers, bronze bush and plates but it still rattles, been like this for 2 years and i still trash the crap out of it. Will change the clutch bearing over the winter to see if that cures it. Andy.
Post by mak595 on Apr 11, 2020 19:14:28 GMT 1
Steve, does mine sound ok? Bit paranoid with it being a lot louder than my 31k Noisy but I've heard worse Steve Any idea what causes it?
Post by mak595 on Apr 11, 2020 19:15:15 GMT 1
Sounds similar to mine Mak, i've changed the basket, cush rubbers, bronze bush and plates but it still rattles, been like this for 2 years and i still trash the crap out of it. Will change the clutch bearing over the winter to see if that cures it. Andy. That's good to know, that it's not going to detonate 😁
F1 Bitsa
Apr 11, 2020 19:24:30 GMT 1
via mobile
Post by midlifecrisisrd on Apr 11, 2020 19:24:30 GMT 1
Same as Andy my 385 is noisy
New idler gear, new billet basket, wiseco rubbers, new crank, new bearings and it is still noisy 😖
Post by roach3 on Apr 11, 2020 21:12:54 GMT 1
mine sounds exactly like that with lotsa new stuff so wouldnt worry too much
Post by mak595 on Apr 12, 2020 10:59:19 GMT 1
Thanks guys, good to get some reassurance that its ok
Post by mak595 on May 6, 2020 14:25:18 GMT 1
MOT done 😁 Also I Was never really happy about the PJ1 I painted the pipes in, really Matt and comes straight off if any petrol drips on them so redone in vht satin black and vht petrol proof laquer Finally I replaced the old seat cover with a all black one One think I did notice was with the fairing on, it makes the engine sound noisier, obviously all the engine noise get amplified and bounced around....
Post by arrow on May 6, 2020 15:21:25 GMT 1
Lookin' good.
Post by Oliver31 on May 6, 2020 18:12:48 GMT 1
What a bike
Post by tdrpete on May 6, 2020 18:32:04 GMT 1
Delectable, cant see an R1 being that desirable in 40 years time. No way.
Post by mak595 on May 7, 2020 15:15:00 GMT 1
Delectable, cant see an R1 being that desirable in 40 years time. No way. Maybe an original '98 model but not the rest
Post by tdrpete on May 7, 2020 17:30:11 GMT 1
My brother had a similar RD LC 2 when i was a kid. I used to love riding on the back and looking down at the exhausts and the accompanying sweet smell of two stroke. Those where the days.
