Post by perazzi350 on May 8, 2020 17:34:50 GMT 1
I have had major problems getting the bike started after I reset the floats to 21 mm I have been kicking the shit out of it all week the best I got was about 20 seconds of running so thought must have big air leak or something did a leak down test at 6.5 lb still at that after 10 mins so a big relief there, must of had carbs off 10 times keep cleaning blowing etc in the end I moved floats again to 22 mm moved needle up one notch and got prepared to kick my nuts out again.. choke out, it started first kick I could not believe it only run it for a few mins as could not breathe in the shed😷. I have a question as I have now moved the needle up one click how much weaker have I made it ? Is it going to be a chance of seizure ? I am also now running premix 32/1 and not oil pump any advice from tuning guru’s ?
Post by 4l04ever on May 8, 2020 20:39:08 GMT 1
Only way to know for sure is to get it checked on a dyno with a gas analyser. Worth the time and money to get it right as it should run better and be safer.
Post by nokturnal on May 10, 2020 14:59:23 GMT 1
did you do the bottom end as well? was the left piston as oily? If no to both... could be leaky right crank seal?
Post by nokturnal on May 10, 2020 15:04:07 GMT 1
also... did that stand bolt on? or did you have to mod it?
Post by perazzi350 on May 10, 2020 15:34:14 GMT 1
did you do the bottom end as well? was the left piston as oily? If no to both... could be leaky right crank seal? Hi mate, no bottom was rebuilt by Rob on here I am absolutely sure it’s 100% did a leak test to really only test what I had done head gasket etc it was all good. Problem was with carbs float settings so at least now it’s running but will get it set up properly later, as for the side stand I had to mod it a bit but nothing to difficult.
Post by 4l04ever on May 10, 2020 16:42:37 GMT 1
Yes, crankcase and seals all leakdown tested when engine was built.
Not sure how good or bad the carbs are...
Post by headcoats on May 11, 2020 12:48:06 GMT 1
I would junk the copies and get some genuine carbs Carbs are a pain in the arse and probably more so if not genuine
Post by perazzi350 on May 11, 2020 13:02:53 GMT 1
I would junk the copies and get some genuine carbs Carbs are a pain in the arse and probably more so if not genuine yes i think that will be the answer a bit later, they have got all `kiehn jets and needles but the inside of the carbs is very rough on casting etc so probably not fuel ing properly, have to wait though at the moment
Post by shaunthe2nd on May 11, 2020 13:25:54 GMT 1
I would junk the copies and get some genuine carbs Carbs are a pain in the arse and probably more so if not genuine yes i think that will be the answer a bit later, they have got all `kiehn jets and needles but the inside of the carbs is very rough on casting etc so probably not fuel ing properly, have to wait though at the moment Tidying out my garage the other day I came across a spare set of standard 4L0-01 carbs I forgot I had. I've started to strip them for an ultrasonic clean but probably be the weekend before I get back onto them to finish them off. If yr interested in buying the set drop me a PM. Shaun.
Post by perazzi350 on Aug 21, 2020 17:27:49 GMT 1
Hi guys latest dyno run from Dave ( Mutts) 67.4hp highest was 68.9 l believe so well happy 😃. Sent bike with new pwk 28’s to be fitted with Mutts new pipes and my end cans , bike was a real pig for him to sort out (sorry Dave) ended up with Dyno pro, and ignitech fitted but also a lot of wiring probs which he sorted out so a massive thanks to you Dave your a star ⭐️ 👍👍
Post by headcoats on Aug 21, 2020 19:11:28 GMT 1
That looks a healthy kick in power!
Post by flames on Aug 21, 2020 19:51:29 GMT 1
Hi guys latest dyno run from Dave ( Mutts) 67.4hp highest was 68.9 l believe so well happy 😃. Sent bike with new pwk 28’s to be fitted with Mutts new pipes and my end cans , bike was a real pig for him to sort out (sorry Dave) ended up with Dyno pro, and ignitech fitted but also a lot of wiring probs which he sorted out so a massive thanks to you Dave your a star ⭐️ 👍👍 Wow, you must be well chuffed with that result. Who tuned the motor? Can't wait to see the finished article. Going to look great with that bodywork on.
Post by flames on Aug 21, 2020 20:30:10 GMT 1
Tho I am very worried about my taste now......I actually like the seat it came with.😞
Post by perazzi350 on Aug 21, 2020 21:32:56 GMT 1
Yea still got that seat 😂😂 I don’t know who tuned the barrels, I contacted the original builder he said they just came in a box of bits, Dave had to do some work on the head, I think squish was to tight ( maybe he will clarify as I am not to sure what it involved) obviously he did all the setting up and other work .
Post by perazzi350 on Aug 31, 2020 12:52:23 GMT 1
Post by perazzi350 on Aug 31, 2020 12:53:01 GMT 1
Been doing some polishing on new pipes😃
2taol
Post by 2taol on Aug 31, 2020 19:39:49 GMT 1
looking good!
the dyno result looks really healthy
looking very positive for the final
Post by perazzi350 on Sept 20, 2020 11:46:21 GMT 1
Post by flames on Sept 20, 2020 12:18:54 GMT 1
What a stunner.
Post by sidney81 on Sept 20, 2020 16:38:26 GMT 1
That's a beauty 😎👌👌
Post by Tobyjugs on Sept 21, 2020 11:07:15 GMT 1
It's great to see a hybrid with the 4LO block. It's a real stunner.
Post by perazzi350 on Oct 14, 2020 16:06:37 GMT 1
Post by 4l04ever on Oct 14, 2020 18:06:10 GMT 1
That is not good :-(
Post by flames on Oct 14, 2020 18:38:11 GMT 1
☹️ are both sides like that?
Post by perazzi350 on Oct 14, 2020 19:04:57 GMT 1
☹️ are both sides like that? No this is nearside L/H barrel other one was black below the rings....Air leak?
Post by headcoats on Oct 14, 2020 19:11:54 GMT 1
You had it set up on the dyno too, so not any mickey mouse settings
Post by perazzi350 on Oct 14, 2020 19:12:57 GMT 1
Hi Rob, no not good sent barrels away to PJ ME for relining, ordered a new crank, genuine seals etc so going to start from scratch over the winter. Is this an air leak or mixture any suggestions?
Post by midlifecrisisrd on Oct 14, 2020 19:20:36 GMT 1
If it was set on the dyno it shouldn't be mixture
Any chance it has stopped oiling that cylinder?
Post by perazzi350 on Oct 14, 2020 19:20:47 GMT 1
You had it set up on the dyno too, so not any mickey mouse settings Yes I know☹️☹️
Post by 4l04ever on Oct 14, 2020 19:22:16 GMT 1
Too late for it now, but you could have done a leak down test after the blow up to see if it was a leak anywhere.
Since you leak down tested it, it is very unlikely to be an air leak.
