Post by jazzyjembreaze on May 31, 2019 0:17:52 GMT 1
Can you run the 175 big bore kits successfully on the oem carburettor Obv changing jets and needle positions, or is the carb to small and it will lean out under load / Thanks in advance / and if not those in the know what should I use I have a Honda CR carb from the early mid 80’s would I stand a better chance , I’d like it to be running slightly rich esp at high RPM Regards mic
Post by Norbo on May 31, 2019 6:49:39 GMT 1
Most people did back in the day but i would not, not nowadays . you need a bigger better carb to feed it at the very least id try and get a 26mm ypvs cab but frankly id be looking at a 28mm if it was me .
Post by mellow on May 31, 2019 7:49:14 GMT 1
Apparently a dt175 carb is the one to use🙄
Post by Norbo on May 31, 2019 9:12:00 GMT 1
Thats a good one yes
Post by jazzyjembreaze on May 31, 2019 10:43:17 GMT 1
Thanks guys 👍
Post by brucie on Jun 1, 2019 13:45:19 GMT 1
I was going to get a big bore on my rd but got talked out of it as he said it would blow the big end in no time is this true or do they last and how many miles thanks
neil
my 125
Post by neil on Jun 1, 2019 20:15:31 GMT 1
I remember reading a tz big end bearing can be used?
Post by 17again on Jun 2, 2019 16:18:26 GMT 1
just use a tuned ypvs barrel much better.
then sauce ypvs using 350 parts.
you only need the pulley and casing
then add a second lever from a bicycle with a cable to one side and a spring to the other.
manual ypvs works great
Post by cinder on Jun 22, 2019 13:59:08 GMT 1
Use a mk3 carb if you want the airbox.I use a 34mm mikuni with no problems
