Post by Dixie Dean on Nov 6, 2019 16:49:57 GMT 1
Hi there can you tell me where you bought your etch clear coat ?
Post by mak595 on Nov 6, 2019 17:00:12 GMT 1
Hi there can you tell me where you bought your etch clear coat ? EBay, check out my other project (F1 bitsa) for a link to the can
Post by Dixie Dean on Nov 6, 2019 17:10:51 GMT 1
How did you rate the buzzweld etch clear coat?
Post by Dixie Dean on Nov 6, 2019 17:25:11 GMT 1
Hi and how many cans did you need?
Post by mak595 on Nov 6, 2019 20:06:09 GMT 1
It seems good stuff, 1 can has done both wheels, the fork bottoms and top yoke and the can isn't empty yet
Post by Dixie Dean on Nov 6, 2019 20:18:49 GMT 1
Thanks will order a can now
Post by Dixie Dean on Nov 8, 2019 16:54:02 GMT 1
Hi what temperature would you advise to use the lacquer.
Post by mak595 on Nov 8, 2019 21:17:55 GMT 1
I just got the can warm in the house, then sprayed the wheel outside but it obviously wasn't as cold as its getting now....
Post by mak595 on Nov 22, 2019 18:48:02 GMT 1
Been looking at the standard pipes, there actually for a F1 with the cut outs, since im building a F1 it makes sense to use them pipes on it... I bought a pair of codnor Microns a while ago off here, for the hydrid that has been put on hold, not really looked at them as i put them straight up into the loft. They came with the original small cans but the lad had made some longer (quieter) cans, the only think is, he made them in mild steel as he was gonna paint them. Anyway, i cleaned up the pipes, first with some harpic then vinegar and tin foil, came up ok for 30+ year old pipes P1020937Here are the original cans P1020938 And here are the "home made" ones P1020940 P1020939Rather than paint the cans, ive polished them then gave them a few coats of etch lacquer so i'll see how they hold up, Here both cans polished up P1020941Repacked the cans with new wadding and a Micron decal as the finishing touch P1020942 P1020943 I've upped the jets to 250's as per DaveW suggestion Finally here a quick vid (if it works), its a bit wooly as it was just running on reserve while i'm filming, it stopped a few seconds after i finished filming... 00001
Post by mak595 on Aug 5, 2020 22:15:40 GMT 1
Done around 500 miles on the bike now, running great, winters job is probably have a look at the forks, the YSS rear shows them up now !! Also a steering damper as it gets a bit lairy at 90 ish 🤣🤣
