Post by ethan on Apr 20, 2019 18:16:33 GMT 1
Hello new to the forum, I've just bought an rd125lc mk1, its been stood since 2007, just done a top end rebuild and had the carb cleaned,fresh fuel oil etc. At first i struggled to get it to tick over but that's sorted now but on a test run it seemed to bog down and struggle for power. Its got a micron on it but the long can style should the jet be altered to account for this when running the standard 12a carburetor. Considering just replacing the existing carb with a copy one from ebay as they are on £20. Any advice appreciated. Thanks
Post by raven13 on Apr 20, 2019 20:32:00 GMT 1
yes you need to up your jets for a micron, No Idea where to start with that as ive never used microns. get your carb cleaned and rebuild rather than the cheap carbs from ebay (tried them they are sh1t at best)
Post by ozzy on Apr 20, 2019 23:57:36 GMT 1
10w carb micron standard air box whats jet size best is...180
10w carb allspeed standard air box whats best size jet...170
10w carb k/n all speed best jet size is...180
The advice norbo gave me.
Oz.
Post by 125lc1dt on Apr 22, 2019 21:20:02 GMT 1
12A Mukini carb ? Main jet only covers mostly the 1/2 to full throttle range. Pilot jet/ throttle valve/ needle / needle jet size, all play their part. Try setting up on throttle position and plug drops to check mixture
Post by ethan on Apr 23, 2019 17:45:00 GMT 1
Yes its a 12a mikuni carburetor I'm trying to source a rebuild kit but struggling to find one. Anyone point me in the right direction. Cheers
Post by 125lc1dt on Apr 23, 2019 20:36:25 GMT 1
Key star are good quality. I sourced my replacement parts via Yamaha as most still available. Also using parts list no’s search on internet works to
neil
my 125
Post by neil on Apr 23, 2019 23:53:43 GMT 1
Strip carb and clean as per Haynes manual.Do you have standard air box? Auto lube? If so 195 main jet won't be far out do a plug chop. Hunt for info on plug chops on here.
Post by bertiemollie on Apr 25, 2019 23:02:37 GMT 1
Strip carb and clean as per Haynes manual.Do you have standard air box? Auto lube? If so 195 main jet won't be far out do a plug chop. Hunt for info on plug chops on here. 195 is standard main jet for a 12a carb. If you run this with a micron you will very likely hole your piston.
neil
my 125
Post by neil on Apr 26, 2019 9:11:52 GMT 1
I ran a standard bike with a bean can micron just raised the needle one position it was ok. All engines are different though. Make sure you run on premium fuel to. To play safe put a 210 main jet in and work from there.
Post by ozzy on Apr 28, 2019 14:07:13 GMT 1
Standard 12a carb settings.
Main jet 195 Air jet 2.5 Needle 5gn36 Clip from top 4 Pilot jet 20 Air screw 1.5 turns out Float height 1.0 mm
