End of this chapter today, being collected by it's excited new owner in the next hour or so
It fought me to the end with running issues.
Would run but lacking in midrange and would go flat or drop the right cylinder every so often
Nearly gave in and fitted desperate 29l carbs that were loaned to me ( Cheers Matt π») and had picked up a good f1 cable since f2 ones were made of unobtainium
Ended up going up a size on pilots, changing floats and setting the fuel level rather than the float height.
Now runs much better but fealt over geared
The penny dropped when I was tidying the shed and found a 16t front sprocket and thought WTF
I thought the only difference in gearing was 41t rear instead of 39t but turns out the front is 16t which I can't get as I needed an offset sprocket to get the chain run correct for the wider 3xc wheel
He'll have to fit a 43t rear to sort it π
