Post by veg on Mar 22, 2020 10:55:58 GMT 1
Matt You might get use hammers and adjustables but the results are always stunning π.
Post by midlifecrisisrd on Mar 22, 2020 11:17:46 GMT 1
Take it you are quiet at work then π
Is it a case of empty fridges don't work so hard so less maintenance π
Good start Steve
Post by Yogi on Mar 22, 2020 17:02:52 GMT 1
muck fe , that looks spot on , can I claim 2nd in queue behind Dusty please mart GUTTED sure it will end up rather nice (like your others ) all the best mart Soz mate π₯΄
Post by Yogi on Mar 22, 2020 17:05:57 GMT 1
Take it you are quiet at work then π Is it a case of empty fridges don't work so hard so less maintenance π Good start Steve Quite the opposite mate they work harder because thereβs more volume to chillπ± Work is manic but Iβm isolating because of the missus suppressed immune system π₯΄ Cheers Matt
Post by Yogi on Mar 22, 2020 17:15:41 GMT 1
Found a nice set of aftermarket drop links amongst my stash so fitted them Fitted the lump that was rebuilt by another forum member but not before checking the top end and replacing the head bolts Result itβs only on +50, Iβll replace all the other wrong bolts when I can get to the platers Mattπ§Έ
kopite30
http://www.motomovers.uk
Post by kopite30 on Mar 23, 2020 18:32:13 GMT 1
Told yeah you would have built by the weekend b ππ
Post by Yogi on Mar 24, 2020 8:32:28 GMT 1
Told yeah you would have built by the weekend b ππ I wished Mikey π₯΄ I spend all day rummaging through sheds,then forget what I was looking for Iβm having all the black painted parts powder coated because they were shite π± I binned the side stand π Hopefully you sent the parts and they will turn up soon or Iβm stuck anyway Matt π§Έ
Post by Yogi on Mar 24, 2020 17:51:48 GMT 1
Had to use the lc2 resto oil pump until I can get another batch off to arrow Total ball ache getting the powder coating off the pump base,I didnβt have another blank at the time π Matt π§Έ
Post by Yogi on Mar 25, 2020 18:02:24 GMT 1
Managed to get the back wheel fitted and most of the electrics cleaned and on Strange thing is I was told this bike was a good runner before the engine rebuild Yet it had the wrong stator and flywheel π€ Matt π§Έ
Post by Yogi on Mar 25, 2020 18:08:18 GMT 1
Due to the virus and everything being shut for the foreseeable Iβve decided to fit some bling for now so I can hopefully use it this summer
Matt π§Έ
kopite30
Post by kopite30 on Mar 25, 2020 20:53:07 GMT 1
Iβll drop mine round so you can finish that b lol,
Looks like you been finishing that by the weekend π
Post by Yogi on Mar 25, 2020 20:57:33 GMT 1
Iβll drop mine round so you can finish that b lol, Looks like you been finishing that by the weekend π If I had all the parts I would π€£ canβt find the bars now π₯΄ Lol, been wondering how it ended up with the wrong stator and flywheel on it ?
kopite30
Post by kopite30 on Mar 25, 2020 21:21:49 GMT 1
ππ oh thatβs low b,π
Have you check the other engine b,
Post by Yogi on Mar 25, 2020 21:50:59 GMT 1
ππ oh thatβs low b,π Have you check the other engine b, Yeah Iβve sorted it now π€£ I need to get the pipes and the rest of the parts on now to see if it will run Wish me luck boyo π€π€
Post by LC_BOTT on Mar 26, 2020 10:06:44 GMT 1
Hi, are the stator/flywheel specific to the N1, and does it all need to match to the 52Y-50 CDI, as I thought this CDI was fitted to several models.
Post by Yogi on Mar 26, 2020 10:17:07 GMT 1
Hi mate
52y-50 was only fitted to the F1 and N1 Afaik
You can make most work with each other but I didnβt want to butcher the loom
Matt π§Έ
kopite30
Post by kopite30 on Mar 26, 2020 17:55:26 GMT 1
ππ oh thatβs low b,π Have you check the other engine b, Yeah Iβve sorted it now π€£ I need to get the pipes and the rest of the parts on now to see if it will run Wish me luck boyo π€π€ Donβt need luck b Darren built that engine be the best you have even seen π first or 2nd kick she will fire up no worries b I got the 31k out the study this morning & round the mancave on the bench ready to finish putting together b,while Iβm waiting for the hybrid bits come back b,
Post by Yogi on Mar 26, 2020 18:24:34 GMT 1
Yeah Iβve sorted it now π€£ I need to get the pipes and the rest of the parts on now to see if it will run Wish me luck boyo π€π€ Donβt need luck b Darren built that engine be the best you have even seen π first or 2nd kick she will fire up no worries b I got the 31k out the study this morning & round the mancave on the bench ready to finish putting together b,while Iβm waiting for the hybrid bits come back b, Iβm not doubting the engine π€ itβs the wiring Iβm worried about π€£π€£
Post by midlifecrisisrd on Mar 26, 2020 19:11:48 GMT 1
Looking good Matt
Did your chain gaurd fit at the front?
I've had 2 and had to cut the front to clear the frame
Post by Yogi on Mar 26, 2020 19:22:55 GMT 1
Looking good Matt Did your chain gaurd fit at the front? I've had 2 and had to cut the front to clear the frame Steve Cheers mate funny you should say that π€ I had to shorten the top hex bolt in the foot plate because it was tight up against it But seems ok now Matt π§Έ
Post by Yogi on Mar 27, 2020 17:19:22 GMT 1
Replaced the foot plates first,,,much happier with the finish now π Found some powder coated switch cases so cleaned,built and added new decals Then used the satin powdered top cover from my spare clock set to build the N1 clocks Was hoping for a call from the coaters to pick up the rest of the parts but no joy there π‘ Matt π§Έ
Post by Yogi on Mar 29, 2020 12:39:17 GMT 1
Built the front end brakes restored by Rd-Bitz Matt π§Έ
Post by midlifecrisisrd on Mar 29, 2020 12:41:30 GMT 1
Oooh! Spendy on the brakes π
Post by Yogi on Mar 29, 2020 12:43:53 GMT 1
Steve Gotta stop the thing π₯΄ I intend riding it all summer ππ
Post by yamark on Mar 29, 2020 15:36:43 GMT 1
As always with your restorations, the bike looks new. There's no stone unturned in "Yogi's sausage factory" Lovely build mate, following with interest
Cheers, Mark
Post by Yogi on Mar 29, 2020 16:54:35 GMT 1
Cheers Mark
I had to open the sausage factory to help feed the nation in these tough times ππππ
Matt π§Έ
Post by Yogi on Mar 30, 2020 13:55:44 GMT 1
Nice of the coaters to drop me some goodies off Matt π§Έ
Post by Yogi on Mar 30, 2020 16:32:13 GMT 1
Fitted the top yoke and bars along with a nos chrome yoke nut (ainβt got a new olive one) Headlight bracket and nos shell fitted,the old ignition will be replaced later Matt π§Έ
Post by Yogi on Mar 31, 2020 12:11:35 GMT 1
Rear end fitted now apart from the indicators Gonna fit these beauties later so Iβve got my old guard dog Yogi watching over them Carbs are going in the ultrasonic cleaner first though Matt π§Έ
Post by dave1963 on Mar 31, 2020 13:39:42 GMT 1
Looking good mate hope you and the mrs are keeping well. Not touched my bikes both are dirty form last couple of blast out with luke and karl a couple of weeks ago . Been playing with me new van and now decorating the living room . Will be glad to get back to work for a rest.
