Post by alistair64 on Feb 2, 2019 13:38:26 GMT 1
Geez, seems like he's just sold out too. Will message him to see when he expects any more. Seems very odd that all of a sudden everyone wants to do this conversion...it's not like it's a new idea or anything.
Post by budgie on Feb 2, 2019 21:50:27 GMT 1
May have to go this way and ditch the 'stat. It seems MBD have sold out of the spacers too according to Martin as they've had a run of orders for them this week. Maybe I should have kept my mouth shut Mine arrived yesterday from Martin.....glad I got in early..!😁
Post by alistair64 on Feb 2, 2019 22:30:25 GMT 1
May have to go this way and ditch the 'stat. It seems MBD have sold out of the spacers too according to Martin as they've had a run of orders for them this week. Maybe I should have kept my mouth shut Mine arrived yesterday from Martin.....glad I got in early..!😁 Yeah, thanks for that. Given that I assume my thread gave you the heads up in the first place, probably not appropriate to be all smug about it.
Post by budgie on Feb 2, 2019 22:42:26 GMT 1
Mine arrived yesterday from Martin.....glad I got in early..!😁 Yeah, thanks for that. Given that I assume my thread gave you the heads up in the first place, probably not appropriate to be all smug about it. Not smug at all, just pleased that your thread and this forum has brought this to many peoples attention... I’m sure Martin will be on the case to get more in stock soon...!
Post by midlifecrisisrd on Feb 2, 2019 22:51:12 GMT 1
Soz if I fecked up and didn't help who I was trying too
Never thought they would be so popular
No doubt more will be made by spring
Post by johnbolton on Sept 28, 2019 9:53:51 GMT 1
So guys.... race YPVS .... stat or no stat.... that is the question...! i have it on a Chinese ebay special Rad..... Gav I run no stat with a standard rad on my race YPVS and its still running a bit hot on a warm day. Is the £65 Chinese ebay special rad any good?? It looks like its only single row. Cant find a 2 row rad for much under £300 John
Post by budgie on Sept 28, 2019 10:55:15 GMT 1
So guys.... race YPVS .... stat or no stat.... that is the question...! i have it on a Chinese ebay special Rad..... Gav I run no stat with a standard rad on my race YPVS and its still running a bit hot on a warm day. Is the £65 Chinese ebay special rad any good?? It looks like its only single row. Cant find a 2 row rad for much under £300 John Hi John I run a race YPVS on track days, I have the 55 degree stat in with spacer... and the chinese rad... Ran at a cold Cadwell yesterday, and had to tape the rad up with gaffa tape to keep it at stat temp... Ran in middle of summer, on day when it was 34 degrees in brillinant sunshine , never exceeded 70 degrees... so I would say mine works fine... and with it being a track bike , only has water in, no antifreeze or special coolant... Gav
Post by jackjabba on Sept 29, 2019 11:13:47 GMT 1
Well finally got around to pulling my 50C stat out of the bike and sure enough it was slightly longer than the original one.
Post by Tobyjugs on Sept 29, 2019 12:19:32 GMT 1
I have two radiators one is a bit rough looking with with a course matrix. looks like it would suit a tractor. The other is very well made looks fantastic with a fine matriix. Both radiators used on the same bike showed that the radiator with the couse matrix worked better than the fine matrix radiator. When i fitted scoops to the radiators it had a good effect on the fine well made radiator and increased the cooling a lot.
Post by Bozzy on Apr 18, 2024 19:42:16 GMT 1
Hi have question about the 55 degree thermo so thought it better to put the question on this post.....
So what's the opinion around the 55 degree stat with spacer with the oversize radiator?... YPVS running halfway and goes through like a two stage warm up ie half way back to 1/4 upto 1/2 back (if not again on odd temp days) and then settles back to just below 1/2 way.
Assume 55 deg would sort out the yoyo but trying to work out how it would run cooler when warmed up? is it due to the spacer and thermo letting more flow through that the standard thermo?
Due to current rebuild thinking it will run hotter for a while and so thinking about the stat change... if I am not going to get much benefit rather not bother as extra cash
Had issue last year in traffic and it got hot sort of 3/4+ but I know they do that and not sure if above stat will sort it?
Post by midlifecrisisrd on Apr 18, 2024 20:01:47 GMT 1
Hi
The stat won't actually make the bike run cooler, the larger rad should help that
Most are happy if the running water temp is 55-65 degrees as the engine is more efficient at that temp
The 50 degree stat won't stop the yoyo as when it initially opens at 50 degrees the rad is full of cold water which then flows into the engine making the temp drop and the stat close till the temp rises again
With the smaller standard rad the volume of water is less so has less effect so less yoyo
If you left the 70 degree stat in your ideal running temp is lower than the stat so it will keep closing and keep the bike at a 70 degree minimum
The 50 degree stat lowers the minimum but if the rad isn't big enough or the flow is wrong it will still run hot
Post by Bozzy on Apr 19, 2024 12:49:43 GMT 1
Thanks Steve.. see now how it can potentially reduce running temps in certain cooler air temp conditions by the stat letting the motor go to a lower temp (especially with larger rad I have) but when hot day see how it perhaps does zero as motor running at 70 deg anyway.
Decision if I spend £57 changing now or ride as is.... recent build costing some substantial pennies... over £1,600 now
Post by Tobyjugs on Apr 20, 2024 8:02:11 GMT 1
This is the best type in my opinion. It just takes more imagination to plum it in. You shouldn’t get any Yo Yo effect with this. This one is from a Super Cart engine. I didn’t fit it at first because I thought it was too small. That opinion has changed now after seeing how big the hole is on the pressure side of the pump. I have also got a bigger version of the above which comes from a snow mobile,
