Post by jazzyjembreaze on Jan 8, 2019 12:21:38 GMT 1
Hi guys another thread another question , So goin through a box of bits I got with the bike I have 2 CDI boxes , What is evident to me after stripping the loom ( what’s original of it ) is some time in the past the MK2 engine had been replaced with a Mk1 , the loom has been ripped apart & so many wires added and ( twist soldered ) on ( pics to follow ) so it’s a pure hack job . My question I know the larger CDI in pics is from a MK2 ( I think 10W -10. Type T1A01-41. HiITACHI made is this correct Any ideas what this smaller box is from Absolutely no markings on at all , is it a MK1 Or not a LC at all Kind regards in advance mic
Post by jazzyjembreaze on Jan 8, 2019 15:00:58 GMT 1
On the smaller box I’ve just scraped a crusted on bit of muck revealing the Yamaha fork symbol, so it’s def a Yamaha CDI but def no other markings the symbol is on the bottom , nothing on either side ‘s Mic
Post by mellow on Jan 8, 2019 18:38:34 GMT 1
The larger square one is mk1 10W and the smaller one is mk2/3 1gu Connectors are hacked off
Post by jazzyjembreaze on Jan 8, 2019 19:14:41 GMT 1
Excellent mellow , ok so I have both I can repair them with connectors no probs ( be as good as new when finished ,,, I’ll get some pics up of my fabulous looking loom after I spent 2 hours removing tape & carefully dissecting it . This will be a tougher job to sort but I will lol
Post by mellow on Jan 8, 2019 19:47:28 GMT 1
Just to recap...... MK1 is 10W Unrestricted 12A Restricted Mk2 is 1GU Mk3 is 2HK Correct Connectors can be found HERE
Post by jazzyjembreaze on Jan 8, 2019 20:12:49 GMT 1
What would be a great help would be pictures of the plugs / so I could see what type to get for each CDI & also wich location to place each wire Hope someone can be of assistance Kind regards mic
Post by jazzyjembreaze on Jan 8, 2019 20:16:44 GMT 1
Thanks mellow Nothing in the smaller box to determine wich it is But as the bike is a 1986 I’m gonna go with mk2
On a de restricted 10w is it just the carb , CDI & exhaust manifold that is the diff from the restricted
Post by jazzyjembreaze on Jan 8, 2019 20:18:29 GMT 1
Thanks for the heads up on plugs / pictures of actual CDI ‘s would still help so I can repair as new
Post by mellow on Jan 8, 2019 20:33:40 GMT 1
i can do you pictures of the plugs tomorrow evening As for restrictions on mk1 i think the 10w carb is ok anyway the 12a carb is different somehow. The 12A probably has a washer in the header pipe of exhaust.
Post by jazzyjembreaze on Jan 8, 2019 20:54:38 GMT 1
Yea that’s great if you could Just ordered that plug set , they do a clear white plastic or black so got the clear white 👍 Your a big help thanks m8 I’ll get some pics up of the loom tomorrow also
Post by mellow on Jan 9, 2019 0:08:05 GMT 1
Here is a detailed wiring diagram. It's for the Mark 3, which is same as Mark 2 except ur cdi may not have the black wire with white stripe that goes to the ypvs control box👍 flic.kr/p/23uwYwcClick on that and you can download the picture. It shows there is 2 male bullets from cdi and a female if you have the black/white wire. Also a 6 pin connector. Will take pictures after work tomorrow🙂
Post by jazzyjembreaze on Jan 9, 2019 16:23:55 GMT 1
My loom as promised ( don’t laugh ha ha ha In pieces Top to bottom White red stripe Yellow White green stripe Solid Red,Black ,Brown with connector Brown Orange Red black stripe Blue Black
Post by jazzyjembreaze on Jan 9, 2019 16:27:35 GMT 1
Next best part of loom I could salvage intact Also various electrical connectors and components Is that the correct rectifier? 3 white wires Also 2 coils in box Any look familiar???
Post by mellow on Jan 9, 2019 18:00:42 GMT 1
Rectifier looks right and bottom coil id say
Post by mellow on Jan 9, 2019 18:12:46 GMT 1
Here is the mk2/3 cdi 2 male bullets 1 female bullet. 1 six way connector but only 5 wires. Sure they are the 2.8mm male ones. Could only find my cut mk1 cdi. There are a few new ones on ebay you could have a look at the pictures. Id guess they will use same types of connectors. Hope this helps
Post by mellow on Jan 9, 2019 19:08:40 GMT 1
Post by jazzyjembreaze on Jan 9, 2019 19:55:36 GMT 1
Thank you mellow 👍👍👍
Post by jazzyjembreaze on Jan 23, 2019 16:06:43 GMT 1
My CDI boxes now Firstly the 10w And secondly the Mk2 , I’m goin to say this is a mk2 as it has 7 wires / not 8 like the one mellow has shown , nothing is missing or cut , 5 on block connector and yellow and red bullet , but no black , I’m goin to stick my neck out and say this must have something to do with either the stator winding or the ypvs servo control unit , ( but looking back as they should , will have no trouble selling the 10w when the time is right 👍 [/url
Post by crm on Jan 24, 2019 22:43:24 GMT 1
Here is the mk2/3 cdi 2 male bullets 1 female bullet. 1 six way connector but only 5 wires. Sure they are the 2.8mm male ones. Could only find my cut mk1 cdi. There are a few new ones on ebay you could have a look at the pictures. Id guess they will use same types of connectors. Hope this helps This with the 3 wires is from a full power Mk3 YPVS 1GU model with working servo. Can i have it please ?
