Post by Trubrit on Oct 26, 2018 18:48:28 GMT 1
Post by dusty350 on Oct 26, 2018 19:02:44 GMT 1
Hi Dave Great to see one of your awesome builds on the forum I'm sure it's gonna be another lovely special. You've been hiding for too long !! Dusty
Post by Trubrit on Oct 26, 2018 19:27:29 GMT 1
Cheers Dusty , Your Pep Talk Obviously Worked :-)
Post by Tobyjugs on Oct 26, 2018 19:54:55 GMT 1
I'm looking forward to this build as well
. I know you have got some nice parts. I hope you go dry clutch.👍👍👍
Post by Trubrit on Oct 26, 2018 20:05:10 GMT 1
I'm looking forward to this build as well . I know you have got some nice parts. I hope you go dry clutch.👍👍👍 Thats My Next Decision Mmmm
Post by Tobyjugs on Oct 26, 2018 20:07:09 GMT 1
Ha ha
Post by 4l04ever on Oct 26, 2018 22:01:46 GMT 1
Looking good. Should be ready for MOT next week at this rate! :-)
Post by JonW on Oct 27, 2018 1:41:33 GMT 1
Wahoo a Dave build! cant wait
Post by Trubrit on Oct 27, 2018 8:01:27 GMT 1
Should Be A Quick Build As 90% Is Bolt On , Bit Of Tube Welding In, The Centre Stand Brackets Had To Go , Found A Few More Nice Bits . Looks Like Its Gonna Be Dry Clutch :-). .
Post by mikee on Oct 27, 2018 8:25:12 GMT 1
Get on with it then
😀 Mike
Post by 1966baz on Oct 28, 2018 9:21:29 GMT 1
Nice looking build there and like the workshop.
Post by tell7437 on Oct 28, 2018 21:57:39 GMT 1
I fancy doing a hydraulic clutch conversion, like the look of that frando slave cylinder
Post by Trubrit on Oct 28, 2018 22:12:07 GMT 1
I fancy doing a hydraulic clutch conversion, like the look of that frando slave cylinder They Work Well, I Have One On My 421 , Just Got A Couple From Muttsnutts :-)
Post by rigga on Oct 28, 2018 22:31:26 GMT 1
Watching this .......
Post by marsbar350 on Oct 28, 2018 22:35:54 GMT 1
finish the tile grouting first before playtime
Post by tell7437 on Oct 28, 2018 22:36:19 GMT 1
I fancy doing a hydraulic clutch conversion, like the look of that frando slave cylinder They Work Well, I Have One On My 421 , Just Got A Couple From Muttsnutts :-) Do they fit on the cable guide on the top case or make a bracket up, also what size master cylinder do you use? . Sorry for all the questions
Post by yamark on Oct 30, 2018 9:38:37 GMT 1
Like the build Dave, great work so far.
Your workshop is far too clean though
Cheers, Mark
Post by Trubrit on Oct 30, 2018 9:44:59 GMT 1
They Work Well, I Have One On My 421 , Just Got A Couple From Muttsnutts :-) Do they fit on the cable guide on the top case or make a bracket up, also what size master cylinder do you use? . Sorry for all the questions Yeah They Fit In The Cable Guide Perfectly Will Get A Pic Later , Will Let You Know How The Master Cylinder Works Out Dave
Post by Tobyjugs on Oct 30, 2018 12:43:26 GMT 1
Hi Dave before you fit your dry clutch engine casing can you measure the diameter of the hole in the engine casing for the dry clutch.
Post by Trubrit on Oct 30, 2018 14:08:08 GMT 1
Hi Dave before you fit your dry clutch engine casing can you measure the diameter of the hole in the engine casing for the dry clutch. Will Do Pal Dave
Post by Trubrit on Oct 30, 2018 14:09:07 GMT 1
Cheers, Mark Ha Ha Its A Bit Messy At The Moment
Post by Trubrit on Oct 30, 2018 19:41:24 GMT 1
Hi Dave before you fit your dry clutch engine casing can you measure the diameter of the hole in the engine casing for the dry clutch. 80mm Pal. .
Post by Trubrit on Oct 30, 2018 19:42:34 GMT 1
They Work Well, I Have One On My 421 , Just Got A Couple From Muttsnutts :-) Do they fit on the cable guide on the top case or make a bracket up, also what size master cylinder do you use? . Sorry for all the questions . .
Post by Tobyjugs on Oct 30, 2018 19:57:01 GMT 1
Cheers Dave
Post by tell7437 on Oct 30, 2018 23:16:36 GMT 1
Thanks for the slave cylinder pic,going to get one for mine. Like the way your going with this project
Post by Trubrit on Jan 25, 2019 12:15:22 GMT 1
Post by Mr Kipling on Jan 25, 2019 16:30:03 GMT 1
This is looking great !!!!!
Post by mouse on Jan 25, 2019 18:46:25 GMT 1
Very different, very nice, liking this a lot!
Mouse
Post by dusty350 on Jan 25, 2019 18:59:49 GMT 1
Looks awesome already Dave - different, and I love the wheels !! Dusty
Post by gazsellars on Jan 25, 2019 19:14:19 GMT 1
Looking Great already Dave!
Gaz
