Post by zxr59 on Mar 21, 2009 0:32:03 GMT 1
Hi all,this is the first time i've tried anything like this its going to be a long job but any helpful tips will be greatly appreciated i'd like to have it all done before the end of the summer but it all boils down to cold hard cash, i'll give it a go and see what happens should have some pics on soon.
Post by lcowner on Mar 21, 2009 11:51:00 GMT 1
hi and welcome mate.just take loads of piccys ,its surprisig how u forget the little things wer they go and stuff.u can use them as a reference wen rebuilding your 4lo later.draw loads of little diagrams aswell for ur self.also the chappys on here are a good bunch of lads and very helpfull.only for them i would never be wer i am now with rebuild and if u have any problems put up a post here and u'l get an answer within a couple of hours. lastly buy yourself a tap n die set cause if it was like my bike there wasent a thread or bolt that hadent to be relaced.and post up loads of piccy's-we love piccy's on here ;Dgood luck
Post by scott on Mar 21, 2009 22:29:32 GMT 1
welcome m8,good luck with the build and as above any trouble just post it up on ea and u should get some answers. if ur powder coatin the frame and other bits i would make sure u stick some old bolts in all the threads and blank off all holes like headstock and swinger pivot point.
Post by zxr59 on Mar 24, 2009 10:59:35 GMT 1
Post by lcowner on Mar 24, 2009 15:20:21 GMT 1
jesus mate your in 4 a rite bit of work der!good luck
Post by wiggy on Mar 24, 2009 19:10:50 GMT 1
oooooooooh foook nasty
Post by scott on Mar 24, 2009 21:43:35 GMT 1
looks nasty m8,good luck
Post by zxr59 on Mar 25, 2009 2:10:34 GMT 1
its not as bad as it looks apart from throwing a big end and disintegrating the piston,barrels are original bore gave them a light hone but its gonna need a rebore,its matching numbers and i did get some good bits with it uncut rear subframe,uncut rear guard,lifting handle and seat locks,headstock still has both vin plates riveted to it,also came with a free butterfly or moth in the cylinder head. more pics soon.
Post by zxr59 on Mar 25, 2009 2:13:16 GMT 1
dont know where it was stood but one side was dry the other wet
Post by canucklehead on Mar 25, 2009 2:14:48 GMT 1
Jeepers, I'd be running away at this point.. Good luck with the build you have more metal than I.
Post by zxr59 on Mar 25, 2009 2:15:35 GMT 1
bobyp
Post by bobyp on Mar 25, 2009 9:29:50 GMT 1
good luck with the build m8,will you post the complete picture of the bike, as of now?huhuhuh..dying to see....
Post by Norbo on Mar 25, 2009 9:39:05 GMT 1
Dood that is sooooooooooo funny
Post by zxr59 on Mar 25, 2009 10:30:18 GMT 1
Post by Norbo on Mar 25, 2009 11:37:23 GMT 1
Unloved, more like abused and smacked about LOL
Post by lcowner on Mar 25, 2009 13:31:27 GMT 1
if i was u mate id try and source a new motor!u could spend money on that and find that u will have to replace cases,crank and whatnot,and u b into serious dollars. mine was bad cosmetically but inards wer good . norbs asked wen he seen a piccy of mine first ''did i find it at the bottom of a lake''LOL,but its amazig wat u can bring back to life........ up to you ,good luck
jonno
Post by jonno on Mar 25, 2009 19:40:26 GMT 1
Looks like a nice project.
The worse they look the more inclined i am to save them.
Greater satisfaction at the end of the day when its completed.
Id stick with it and rebuild it, that way you know what you've got at the end of the day and you will enjoy riding it harder knowing it will hold together. ;D
Good luck and keep the pictures coming.
hondablade
2 wheels ~ 2 Strokes
Post by hondablade on Mar 25, 2009 20:07:24 GMT 1
Yeh i agree with the above, take that engine from literally mothballed to its former glory. Good Luck!!
Post by carlos on Mar 25, 2009 20:38:52 GMT 1
Armstrong Engineering at the bottom of Westgate Road in Newcastle used to be very good for re-bores etc! Not too far from Durham
jonno
Post by jonno on Mar 26, 2009 10:00:12 GMT 1
Thats a lovely job Gary, well done mate.
Post by lcowner on Mar 26, 2009 14:00:37 GMT 1
cant argue wit that gaz......
Post by carlos on Mar 26, 2009 17:31:13 GMT 1
If it's got matching numbers you've gotta restore the cases!
Post by zxr59 on Mar 26, 2009 18:58:34 GMT 1
Post by zxr59 on Mar 26, 2009 19:00:16 GMT 1
Post by scott on Mar 26, 2009 22:47:00 GMT 1
never mind messin wiv that bike m8,get the grass cut ;D
Post by carlos on Mar 27, 2009 0:17:13 GMT 1
never mind messin wiv that bike m8,get the grass cut ;D SHHHHH my grass needs cut !
Post by zxr59 on Mar 27, 2009 1:17:29 GMT 1
dont really do gardening scott it will be a lot longer before i get round to it heheheh
Post by Norbo on Mar 27, 2009 13:01:51 GMT 1
;D So this is like the broom still looking new after 10 years only had 15 new brushes and 11 new handles.
