angus4
Post by angus4 on Apr 2, 2018 10:17:04 GMT 1
Hi After many years of collecting and storing bits, I've finally made a start on the build. 1991 was the last 350LC I built up from several boxes of bits, so bear with me. I'm not going to build a show condition bike....just one I can use without worrying about it getting the odd scratch or wet:) Here is the frame with RGV250 rear & front end Today I fitted a few parts including the loom....does this look about right for routing? I'm still not sure if to keep the Wranger paintwork I have a 350 engine I need stripping down to check what needs doing. The barrels look to have been machined down, so may have DT175 pistons fitted? A lot to learn here, so expect quite a few questions....
Post by dusty350 on Apr 2, 2018 10:32:28 GMT 1
Post by veg on Apr 2, 2018 12:27:25 GMT 1
Saw Wrangler and got so excited, my first 350Lc was going to be a wrangler i was px, ing my highly modified Suzuki 550 katana, braced arm 4;1 alfa pipe alloy bars belly pan you know the thing the full M&P catalogue rode down to Essex to do the deal the guy rode mine came back and said kin ell its gutless and I was heart broken so I have always had a soft spot so sort those pics and welcome.
angus4
Post by angus4 on Apr 2, 2018 13:15:51 GMT 1
Thanks....hopefully the pics work now...
Post by Mr Kipling on Apr 2, 2018 13:42:26 GMT 1
hi , looks like u got a nice project too keep u busy for a while , enjoy the build more importantly enjoy the forum...
Post by jon on Apr 2, 2018 14:24:13 GMT 1
Is that a Volkswagen camper front beam in the pics?
angus4
Post by angus4 on Apr 2, 2018 15:46:13 GMT 1
Its is mate...good spot.....1965
Post by yamark on Apr 2, 2018 17:14:55 GMT 1
Hi Angus, and welcome to the Forum. Nice work so far - as for your question on the loom route, the main loom should be on the right hand side of the head stock, then as it goes back under the tank - in the position you have it.
Hope that helps
Cheers, Mark
angus4
Post by angus4 on Apr 2, 2018 19:16:20 GMT 1
Thanks Mark
I thought with the cable guide on the left hand side as you sit on the bike it routes that way. What is that guide for then... Cables?
Post by dllc on Apr 3, 2018 12:14:12 GMT 1
What is that guide for then... Cables? yes throttle and tacho if barrells are machined so you only see half of the 347, then more than likely dt175mx pistons are in it at a 66mm bore giving you approx 375cc
good luck with the build, keep the wrangler look until you have it all up and running, it will be class
rgds
d
angus4
Post by angus4 on Apr 5, 2018 20:04:05 GMT 1
Thanks for the help....may stick with the Wrangler look:)
