Post by 4l04ever on Mar 29, 2018 17:44:37 GMT 1
Hi All
I am looking at strengthening the frame at the swingarm points, so will need a longer swing arm spindle. Would a YPVS one do the job?
Many Thanks
Post by JonW on Mar 29, 2018 21:54:49 GMT 1
I used a ypvs on mine, I cut the end off and rethreaded it further. Worked well and I also rezinc'd the pin, came up a treat. When you make the bobbins to space out the swinger plates, cut (mill) one to fit the head of the pin ala ypvs, tho i did it so its fits on both sides not just one. The ypvs pin even tho its waisted, is much stronger than the LC as its not drilled for grease nipples. FYI pics of all the strengthening work I did are at bottom of this page: 2smoked.com/Yamaha_RD350_LC_421cc_Athena_Frame.html
Post by donkeychomp on Mar 29, 2018 22:47:49 GMT 1
Think you have to change the bearings too...but I could be wrong. Normally am lol.
Post by tell7437 on Mar 29, 2018 23:01:33 GMT 1
An aircooled rd spindle would do
Post by 4l04ever on Mar 30, 2018 11:48:17 GMT 1
I will get an LC swingarm spindle measured and then get the aircooled and YPVS sizes :-)
Post by jon on Mar 30, 2018 11:59:43 GMT 1
Hi All I am looking at strengthening the frame at the swingarm points, so will need a longer swing arm spindle. Would a YPVS one do the job? Many Thanks Hi 4l04ever, The YPVS spindle will still be about 24mm too long so you’ll have the rethread the end as Jonw suggested. I’ve got a YPVS spindle in mine, but that’s not only the strengthened webs added, but also I’ve spread the frame for more chain clearance with a 4.5” rear wheel. Jon
Post by 4l04ever on Mar 30, 2018 12:04:46 GMT 1
Cheers
It sounds like a YPVS spindle has enough extra length to do what I need :-)
hes
Newbe
Post by hes on Jan 15, 2020 14:59:02 GMT 1
I used a ypvs on mine, I cut the end off and rethreaded it further. Worked well and I also rezinc'd the pin, came up a treat. When you make the bobbins to space out the swinger plates, cut (mill) one to fit the head of the pin ala ypvs, tho i did it so its fits on both sides not just one. The ypvs pin even tho its waisted, is much stronger than the LC as its not drilled for grease nipples. FYI pics of all the strengthening work I did are at bottom of this page: 2smoked.com/Yamaha_RD350_LC_421cc_Athena_Frame.html Hi there johw I have red your info I am currently starting a project yamaha rd lc 350 I want to take on the path just like yours with the nessesary spending So i want to know how to get in contact with you
Post by veg on Jan 15, 2020 17:13:36 GMT 1
Click on jons avatar send him a pm private message.
