Post by dusty350 on Mar 12, 2021 19:53:26 GMT 1
Hi Steve Yea, I wasn't sure how they would fit an aircooled frame with a Pv engine. I was careful at the early build stage to make sure the engine sat central in the frame as the downpipe exit is obviously very important ! I dont think these could have fitted any better, even if I had taken it up to Jim, which was originally my plan, pre Covid. I dont mind loud !! I had these pipes on my Red/white Lc hybrid, and loved how they sounded, although these have that 80mm exit pipe which may make a bit of difference. Thankfully I've got good neighbours !! Dusty
Post by Yogi on Mar 12, 2021 19:58:53 GMT 1
Even better if you had deaf neighbours π€£
Looking good Dusty boy π
Post by donkeychomp on Mar 12, 2021 22:35:39 GMT 1
They look amazing mate. Trying to imagine them polished. Also trying to imagine the noise!
Post by Mr Kipling on Mar 13, 2021 13:46:45 GMT 1
wow glad the pipes are fitting quite well , i too like Steve woulda been sweating it, look forward too see them both polished n fitted , atb...
Post by dusty350 on Mar 13, 2021 21:37:09 GMT 1
Hey Mr K. - how are you ? I wasn't too worried regards pipe fitment - if they had been miles out I knew I could sell them on as Ypvs pipes, and then would have to had come up with another plan ! I did have a minor concern after looking at Mouse's Pv frame - the Pv frames aren't as flat under the engine as the Ac's are, and I did wonder whether the pipe would contact the Ac frame where it wouldn't on a valve, but it's fine. The left side was my main concern due to side stand and chain, but I dont think it would fit any better if Jim had the bike up at his place ! It's really good, nice and tucked in and clears with the chain too. I spent today getting the exhaust flanges fitted. I had 2 new pv crush washers, which I glued in place last night with clear silicon gasket goo; 20210312_211453 by dusty miller, on Flickr I wanted to make some spacers for the exhaust flanges - if you fit them without it's easy to bend the edges of the flange when tightening up the bolts. Spacers will allow the flange to crush the washer but not go as far as bending the metal flange. Had to do some careful measuring, then got on the lathe and turned up 4 ali spacers; 20210313_131002 by dusty miller, on Flickr 20210313_135034 by dusty miller, on Flickr I also selected 4 stainless bolts which I had to cut to the right length to get as much thread into the barrel as possible - too shallow a bolt can pull threads out when tightened. Again, did some measuring first, then cut the overlong bolts down, before putting them in the lathe and machining a clean finish on the heads, then polishing them ! (think my OCD is getting worse !!) With the flanges permanently fixed, I could fit the right hand exhaust - easier than the left side !; 20210313_135654 by dusty miller, on Flickr My next job is to cut and shape the rear mounting brackets, from stainless steel strips that Dave packaged with the exhausts. I have drilled a separate mounting hole in the left rearset plate, and can now design the bracket. Even though it wont be seen, I wanted to shape the top edge of the bracket, and used a bench sander I bought from Lidl a few weeks back. Cost about Β£30, but what a great little machine for shaping brackets; 20210313_151633 by dusty miller, on Flickr I can see me using that a lot in the future Dusty
Post by sidney81 on Mar 13, 2021 22:15:45 GMT 1
Great work dusty π
Post by mak595 on Mar 14, 2021 21:26:18 GMT 1
Dusty, i used the same strip for my Alonze pipes but i wish i'd either used thicker plate or a wider triangle bracket as my pipes have quite a bit of movement with only the thin strip....
Think i'm gonna either weld another strip onto it to beef it up or make a wider bracket
Post by dusty350 on Mar 14, 2021 21:42:15 GMT 1
Hi The brackets are 2 strips welded together - Dave/Jim supplied 4 strips - 2 for each side; 20190109_185901 by dusty miller, on Flickr Not the clearest pic but there are 2 strips welded together, with the front strip bent forward, the rear strip straight down. I plan to copy that as it was fine on that build Dusty
Post by Mr Kipling on Mar 15, 2021 18:18:43 GMT 1
Hey Mr K how r u ? Dusty :) hi Dusty , i,m not too bad , thxs...waiting patiently for the world to get back too normal... Your bikes coming along nicely keep the pics a coming.... Atb...
Post by mak595 on Mar 15, 2021 23:22:39 GMT 1
Hi The brackets are 2 strips welded together - Dave/Jim supplied 4 strips - 2 for each side; 20190109_185901 by dusty miller, on Flickr Not the clearest pic but there are 2 strips welded together, with the front strip bent forward, the rear strip straight down. I plan to copy that as it was fine on that build Dusty Ahh, that would explain why i had 4 strips and only used 2
Post by dusty350 on Mar 16, 2021 20:34:16 GMT 1
Made the brackets for the left side exhaust this afternoon. I'm replicating what Jim does as standard, as best I can, so made the angled bracket first, then took the pipe down the road to Glen so he could tack weld it in place; 20210316_190332 by dusty miller, on Flickr 20210316_190633 by dusty miller, on Flickr I then made up another bracket that will be welded to this angled one, but will go straight down onto the pipe and welded in place, to make a strong fixing. Will pop back to Glen tomorrow for the final weld, then I will fit it to the bike and start on the other side, replicating the angle and distance from the swingarm the exhaust needs to be at to be a mirror image of the left side - then I can make the bracket to fit. Dusty
Post by mouse on Mar 16, 2021 21:18:39 GMT 1
Looks like you got the bracket in the right position first time! Nice work
Mouse
Post by dusty350 on Mar 16, 2021 21:31:15 GMT 1
Cheers mate - took some time to get the bracket right to be honest - not the 5 minute job I thought it would be !! I hope to have it all fully welded by the weekend so I can polish everything and get them fitted Dusty
Post by andy748 on Mar 16, 2021 21:50:12 GMT 1
Looks like a right faff getting them positioned correctly, but you've done a great job (as expected), are they rubber mounted on the back Dusty? Andy.
Post by dusty350 on Mar 17, 2021 7:59:48 GMT 1
Hi Andy I plan to make a rubber buffer between the bracket and the footrest hanger, to save some of the vibes getting through ! Dusty
Post by sidney81 on Mar 17, 2021 8:08:37 GMT 1
Hi dusty great work !! Have you ever thought about getting a little tig welder and having ago ??
Post by dusty350 on Mar 17, 2021 8:29:19 GMT 1
Hi Chris Yea, it's crossed my mind to do a night school welding course. A mate did one some years back but it wasn't cheap, and he has only welded one thing since ! I dont know if I would weld enough stuff to make it worthwhile, plus I am lucky to have Glen down the road who will make such a good job of anything I need doing, I feel it easier just to take stuff to him. I do want to improve my skills with the lathe though, and have just bought a 4 jaw chuck with reversible jaws. My other chuck only had the internal jaws with it which made machining smaller parts difficult - I had to get inventive to make those exhaust flange spacers ! I need another project bike at some point to really get the use from the lathe - virtually all the machined parts for my current 2 bikes are already done. I love using it though, and I'm constantly looking at existing parts that could be shaped/scalloped/improved, but I'm running out !! Dusty
Post by sidney81 on Mar 17, 2021 9:43:06 GMT 1
Yep fair play dusty that makes sense πyes the lathe on the other had thers so much can be done on them , especially with a 4 jaw or a face plate ! I'm like that keep thinking hummm what can I turn π€£π€£
Post by dusty350 on Mar 17, 2021 20:29:08 GMT 1
Post by mouse on Mar 17, 2021 22:27:56 GMT 1
Lovely job!
mouse
Post by Mr Kipling on Mar 18, 2021 12:41:04 GMT 1
Superb job, cant wait to see em polished n final fit....
Post by dusty350 on Mar 18, 2021 21:45:05 GMT 1
Post by oldbritguy on Mar 18, 2021 22:27:40 GMT 1
Pipes look great Dusty and fitting nice and even. All that fettling has definitely paid off. I agree that rubber mounting will iron out loads of the vibes plus significantly reduce the likelihood of the brackets cracking along those lovely welds. Could you get the hangers machined to take a couple of steel sleeved rubber bushes? That would definitely do the trick. More work thoβ. This is gonna turn out another top special, again, well done. John
Post by donkeychomp on Mar 18, 2021 22:28:18 GMT 1
Bloody hell what a difference! Nice one matey.
Post by dusty350 on Mar 19, 2021 19:02:52 GMT 1
Post by midlifecrisisrd on Mar 19, 2021 19:13:45 GMT 1
They do look awesome Dusty
Is there enough meat in the hanger to bore a hole the same size as the one in LC standard hangers so you can use the rubber bung and sleeve that goes through it from the LC
Post by dusty350 on Mar 19, 2021 20:15:31 GMT 1
Hi Steve Yea, I was thinking along those lines as I have some spare Lc exhaust hanger rubbers in the shed. The footrest plate is 12mm thick so I should be able to do something with them Dusty
Post by abar121 on Mar 19, 2021 20:44:16 GMT 1
That is looking wonderful!
Top job!
Post by dusty350 on Mar 19, 2021 20:59:31 GMT 1
Thanks I started this project 3 years ago - 26-3-18 !! I must try harder !! Also fitted the new petrol taps that have been in the drawer since I bought them in 2019 20210319_131253 by dusty miller, on Flickr New Yamaha petrol hose fitted. Need to find suitable fibre washers for sealing the tap to the tank. Dusty
Post by sidney81 on Mar 19, 2021 22:37:44 GMT 1
Hi dusty the pipes look lovely ,the short end cans really suit it π
